Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
InfiniBand QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding InfiniBand Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber InfiniBand Cables
Route the InfiniBand Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting InfiniBand cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Display Subnet Manager Status
Display Subnet Manager Location History
Display Subnet Manager Priority, Controlled Handover State, Prefix, Management Key, and Routing Algorithm
Display the Secret M_Key Configuration
Verify M_Key Persistence
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Set the Subnet Manager Prefix
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Readable Management Key
Clear the Subnet Manager Readable Management Key
Set the Subnet Manager Routing Algorithm
Enable the Subnet Manager
Disable the Subnet Manager
Configuring Secure Fabric Management
Secret M_Key Overview
smsubnetprotection Command
Prepare for Secret M_Key Functionality
Configuring Secret M_Keys
Create the Secret M_Key Configuration
Add Secret M_Keys to the Configuration
Set the Secret M_Key to Use
Delete Secret M_Keys From the Configuration
Configure a Local Secret M_Key
Set the Replication Password
Enable or Disable Secret M_Key Persistence
Enable or Disable Secret M_Key Functionality
Considering Situations In Regard to Secret M_Key
Add a New Subnet Manager to the Secret M_Key Fabric
Merge Subnets Into One Secret M_Key Fabric
Secret M_Key and Firmware Upgrade and Downgrade Guidelines
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing InfiniBand Cables
Inspecting the InfiniBand Cables
Remove an InfiniBand Cable
Install an InfiniBand Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Replace the Battery
Reference
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
dcsport Command
delete_ipoib Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
Note - There is a maximum of 10 secret M_Keys for the configuration.
  1. Initiate a secret M_Key configuration session on the management controller that hosts the master Subnet Manager.
    FabMan@switch_name->smsubnetprotection start -addonly
  2. Display the active secret M_Key configuration.
    See Display the Secret M_Key Configuration.
  3. Add an M_Key to the configuration.
    FabMan@switch_name->smsubnetprotection add m_key
    where m_key is the management key (16 hexadecimal digits).
    For example:
    FabMan@switch_name->smsubnetprotection add 0x00abcdefabcdef03
    Mkey added
  4. Repeat Step 3 for any additional M_Keys you want to add to the configuration.
  5. (Optional) If you will use one of the just added secret M_Keys, set the M_Key to use.
    FabMan@switch_name->smsubnetprotection set-current m_key
    For example:
    FabMan@switch_name->smsubnetprotection set-current 0x00abcdefabcdef03
    Mkey 0x00abcdefabcdef03 updated
    Note - You can only set an M_Key which has been added to the configuration.
  6. Display the pending M_Keys.
    FabMan@switch_name->smsubnetprotection list modified
    # File_format_version_number 1
    # Sun DCS IB mkey config file
    # This file is generated, do not edit
    # secretmkey=enabled
    # nodeid=mnm
    # time=15 Dec 03:47:12
    # checksum=0
    #! commit_number : 3
    Mkey                    Untrusted Mkey          Smkey                   Attribute
    0x00abcdefabcdef01      0x1aa45124fee612ae      0x15fc26aea300f831
    0x00abcdefabcdef02      0x4ccd8230de6cd348      0x3fc7e6ad701a8a2a      C
    0x00abcdefabcdef03      0x9baa1debcc74de5e      0x1b253003600d137b      S
    In the output, the Attribute heading identifies:
    • C – The current secret M_Key
    • S – The standby secret M_Key
  7. End the session and commit the secret M_Key configuration to the master Subnet Manager.
    FabMan@switch_name->smsubnetprotection commit
    The configuration is distributed to the trusted standby Subnet Managers and the current secret M_Key to the InfiniBand Fabric.
Related Information
