Comparison of IKEv2 and IKEv1
The following table compares the implementation of the IKEv2 and IKEv1 versions
on an Oracle Solaris system.
Table 8-1 IKEv2 and IKEv1 Implementation
in Oracle Solaris
| Implicit based on objects in keystore
| cert_trust parameter in ike/config file
Certificate creation
| ikev2cert command
| ikecert certlocal command
Certificate import
| ikev2cert import command can import certificates and keys into PKCS #11 keystore
| ikecert certdb command can import standalone certificates into IKE keystore
Certificate owner |
ikeuser
root
Certificate policy file
| kmf-policy.xml
| Some policy in ike/config file
Certificate storage
| PKCS #11 softtoken library
| Local IKEv1 databases
Configuration file directory
| /etc/inet/ike/
| /etc/inet/ike/ and /etc/inet/secret/
Configuration owner
| ikeuser account
| root account
Daemon
| in.ikev2d
| in.iked
FIPS 140 algorithms for
traffic between daemons
The Cryptographic Framework feature of Oracle Solaris 11.1 SRU 5.5 and SRU 3 is validated for
FIPS 140-2, Level 1. If FIPS 140 mode is enabled and the Cryptographic
Framework is being used, then FIPS 140-validated algorithms are used. By default,
FIPS 140 mode is not enabled.
IKE SAs use the Cryptographic Framework
Not all exchanges use the Cryptographic Framework
FIPS 140 algorithms for IPsec traffic
Use the Cryptographic Framework
IKE policy file
| ike/ikev2.config
| ike/config
IKE preshared keys
| ike/ikev2.preshared
| secret/ike.preshared
NAT port
| UDP port 4500
| UDP port 4500
Port
| UDP port 500
| UDP port 500
Rights profile
| Network IPsec Management
Service name (FMRI)
| svc:/ipsec/ike:ikev2
| svc:/ipsec/ike:default
