man pages section 1: User Commands
Exit Print View
Updated: July 2014
echo (1g)
Name
echo - display a line of text
Synopsis
echo [SHORT-OPTION]... [STRING]...
echo LONG-OPTION
Description
User Commands                                             ECHO(1)
NAME
SYNOPSIS
     echo LONG-OPTION
DESCRIPTION
     Echo the STRING(s) to standard output.
     -n   do not output the trailing newline
     -e   enable interpretation of backslash escapes
     -E   disable interpretation of backslash escapes (default)
     --help
          display this help and exit
     --version
          output version information and exit
     If -e is in effect, the following sequences are recognized:
     \\   backslash
     \a   alert (BEL)
     \b   backspace
     \c   produce no further output
     \e   escape
     \f   form feed
     \n   new line
     \r   carriage return
     \t   horizontal tab
     \v   vertical tab
     \0NNN
          byte with octal value NNN (1 to 3 digits)
     \xHH byte with hexadecimal value HH (1 to 2 digits)
     NOTE:  your  shell  may  have its own version of echo, which
     usually supersedes the version described here.  Please refer
     to  your shell's documentation for details about the options
GNU coreutils 8.16   Last change: March 2012                    1
     it supports.
AUTHOR
     Written by Brian Fox and Chet Ramey.
REPORTING BUGS
     Report echo bugs to bug-coreutils@gnu.org
     GNU coreutils home page:  <http://www.gnu.org/software/core-
     utils/>
     General  help  using GNU software: <http://www.gnu.org/geth-
     elp/>
     Report  echo  translation  bugs  to  <http://translationpro-
     ject.org/team/>
COPYRIGHT
     Copyright  (C)  2012 Free Software Foundation, Inc.  License
     GPLv3+:     GNU     GPL     version     3      or      later
     <http://gnu.org/licenses/gpl.html>.
     This  is  free  software:  you are free to change and redis-
     tribute it.  There is NO WARRANTY, to the  extent  permitted
     by law.
ATTRIBUTES
     See   attributes(5)   for   descriptions  of  the  following
     attributes:
     |ATTRIBUTE TYPE |  ATTRIBUTE VALUE   |
     |Availability   | file/gnu-coreutils |
     |Stability      | Uncommitted        |
SEE ALSO
     The full documentation for echo is maintained as  a  Texinfo
     manual.    If  the  info  and  echo  programs  are  properly
     installed at your site, the command
          info coreutils 'echo invocation'
     should give you access to the complete manual.
NOTES
     This  software  was   built   from   source   available   at
     https://java.net/projects/solaris-userland.    The  original
     community       source       was       downloaded       from
     http://ftp.gnu.org/gnu/coreutils/coreutils-8.16.tar.xz
     Further  information about this software can be found on the
GNU coreutils 8.16   Last change: March 2012                    2
     open source community  website  at  http://www.gnu.org/soft-
     ware/coreutils/.
GNU coreutils 8.16   Last change: March 2012                    3
