man pages section 1: User Commands
Exit Print View
Updated: July 2014
intel_upload_blit_small (1)
Name
intel_upload_blit_small - formance
Synopsis
Description
User Commands                          intel_upload_blit_small(1)
NAME
     intel_upload_blit_small  -  microbenchmark of Intel GPU per-
     formance
SYNOPSIS
DESCRIPTION
     intel_upload_blit_small is a  microbenchmark  tool  for  DRM
     performance.   It  should  be  run  with  kernel modesetting
     enabled, and may require root privilege for  correct  opera-
     tion.  It does not require X to be running.
     Given  that  it  is a microbenchmark, its utility is largely
     for regression testing of the kernel, and  not  for  general
     conclusions on graphics performance.
ATTRIBUTES
     See   attributes(5)   for   descriptions  of  the  following
     attributes:
     |      ATTRIBUTE TYPE         |       ATTRIBUTE VALUE         |
     |Availability                 |x11/diagnostic/intel-gpu-tools |
     |Interface Stability          |Volatile                       |
X Version 11     Last change: intel-gpu-tools 1.3               1
