man pages section 1: User Commands
Exit Print View
Updated: July 2014
sun(1)
Name
machid, sun, i386, i486, sparc - get processor type truth value
Synopsis
sun
i386
sparc
Description
The following commands will return a true value (exit code of 0) if you are using an instruction set that the command name indicates.
sun
True if you are on a Sun system.
i386
True if you are on a computer using an iAPX386 processor.
sparc
True if you are on a computer using a SPARC-family processor.
The commands that do not apply will return a false (non-zero) value. These commands are often used within makefiles (see make(1S)) and shell scripts (see sh(1)) to increase portability.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/core-os
See also
make(1S), sh(1), test(1), true(1), uname(1), attributes (5)
Notes
The machid family of commands is obsolete and could be deleted in a future release of Oracle Solaris. Use uname –p instead.
