man pages section 1: User Commands
Exit Print View
Updated: July 2014
swift-ring-builder (1)
Name
swift-ring-builder - OpenStack Swift ring builder
Synopsis
swift-ring-builder   <builder_file>  <commands>  <arguments>
Description
OpenStack Swift                             swift-ring-builder(1)
NAME
SYNOPSIS
DESCRIPTION
     The swift-ring-builder utility is used to create, search and
     manipulate  the swift storage ring. The ring-builder assigns
     partitions to devices and writes an optimized Python  struc-
     ture  to a gzipped, pickled file on disk for shipping out to
     the servers. The server processes just check  the  modifica-
     tion  time of the file occasionally and reload their in-mem-
     ory copies of the ring structure as needed. Because  of  how
     the  ring-builder  manages  changes  to  the  ring,  using a
     slightly older ring usually just  means  one  of  the  three
     replicas  for  a subset of the partitions will be incorrect,
     which can be easily worked around.
     The ring-builder also keeps its own builder  file  with  the
     ring  information  and  additional  data  required  to build
     future rings. It is very important to keep  multiple  backup
     copies  of  these  builder  files. One option is to copy the
     builder files out to every server  while  copying  the  ring
     files  themselves.   Another  is to upload the builder files
     into the cluster itself. Complete loss  of  a  builder  file
     will  mean creating a new ring from scratch, nearly all par-
     titions will end  up  assigned  to  different  devices,  and
     therefore  nearly all data stored will have to be replicated
     to new locations. So, recovery from a builder file  loss  is
     possible,  but  data  will  definitely be unreachable for an
     extended time.
     If invoked as 'swift-ring-builder-safe' the  directory  con-
     taining  the  builder  file  provided  will be locked (via a
     .lock file in the files parent directory).  This provides  a
     basic  safe  guard  against multiple instances of the swift-
     ring-builder (or other utilities  that  observe  this  lock)
     from  attempting  to write to or read the builder/ring files
     while operations are in progress.  This  can  be  useful  in
     environments  where  ring  management has been automated but
     the operator still needs to interact with  the  rings  manu-
     ally.
SEARCH
     <search-value>
          Can be of the form:
OpenStack             Last change: 8/26/2011                    1
          d<device_id>z<zone>-<ip>:<port>/<device_name>_<meta>
          examples:
          Any  part  is  optional,  but you must include at least
               one,
             d74              Matches the device id 74
             z1               Matches devices in zone 1
                1.2.3.4
             z1-1.2.3.4        Matches  devices  in zone 1 with
                  the ip
                1.2.3.4
             1.2.3.4           Matches devices in any zone with
                  the ip
                5678
             z1:5678           Matches  devices  in  zone 1 using
                  port
             :5678            Matches devices that use port 5678
                sdb1
             /sdb1             Matches  devices  with  the device
                  name
                data
             _shiny            Matches  devices with shiny in the
                  meta
                the meta data
             _'snet:  5.6.7.8'  Matches  devices with snet:
                  5.6.7.8 in
                ::1
             [::1]             Matches devices in any zone with
                  the ip
                and port 5678
             z1-[::1]:5678     Matches  devices  in zone 1 with
                  ip ::1
          Most specific example:
             d74z1-1.2.3.4:5678/sdb1_"snet: 5.6.7.8"
          Nerd explanation:
                the ip, in which case the - is optional unless
        the device         id or zone is also included.
             All  items  require  their single character prefix
                  except
COMMANDS
     <builder_file>
          Shows  information  about  the  ring  and  the  devices
          within.
OpenStack             Last change: 8/26/2011                    2
     search  <search-value>
          Shows information about matching devices.
     add z<zone>-<ip>:<port>/<device_name>_<meta> <weight>
     add r<region>z<zone>-<ip>:<port>/<device_name>_<meta>
          <weight>
<meta> -w <weight>
     add  -r  <region> -z <zone> -i <ip> -p <port> -d
          <device_name> -m
          Adds  a  device to the ring with the given information.
          No partitions will be assigned to the new device  until
          after running 'rebalance'. This is so you can make mul-
          tiple device changes and rebalance them all just  once.
     create <part_power> <replicas> <min_part_hours>
          Creates  <builder_file>  with 2^<part_power> partitions
          and <replicas>.  <min_part_hours> is number of hours to
          restrict moving a partition more than once.
     list_parts <search-value> [<search-value>] ..
          Returns  a 2 column list of all the partitions that are
          assigned to any of the devices matching the search val-
          ues  given.  The first column is the assigned partition
          number and the second column is the  number  of  device
          matches  for  that  partition. The list is ordered from
          most number of matches to least. If there are a lot  of
          devices  to  match  against,  this command could take a
          while to run.
     rebalence
          Attempts to rebalance the ring  by  reassigning  parti-
          tions that haven't been recently reassigned.
     remove <search-value>
          Removes  the  device(s) from the ring. This should nor-
          mally just be used for a device that has failed. For  a
          device  you  wish to decommission, it's best to set its
          weight to 0, wait for it to drain all  its  data,  then
          use  this  remove  command.  This  will not take effect
          until after running 'rebalance'.  This is  so  you  can
          make  multiple  device  changes  and rebalance them all
          just once.
     set_info <search-value> <ip>:<port>/<device_name>_<meta>
          Resets the device's information. This information isn't
          used  to assign partitions, so you can use 'write_ring'
OpenStack             Last change: 8/26/2011                    3
          afterward to rewrite the current ring  with  the  newer
          device  information.  Any  of the parts are optional in
          the final  <ip>:<port>/<device_name>_<meta>  parameter;
          just  give  what  you  want  to  change.  For  instance
          set_info d74 _"snet: 5.6.7.8"  would  just  update  the
          meta data for device id 74.
     set_min_part_hours <hours>
          Changes the <min_part_hours> to the given <hours>. This
          should be set to however long a full replication/update
          cycle  takes.  We're working on a way to determine this
          more easily than scanning logs.
     set_weight <search-value> <weight>
          Resets the device's weight. No partitions will be reas-
          signed  to  or  from  the  device  until  after running
          'rebalance'. This is so you can  make  multiple  device
     validate
          Just runs the validation routines on the ring.
     write_ring
          Just rewrites the distributable ring file. This is done
          automatically after a successful rebalance,  so  really
          this  is only useful after one or more 'set_info' calls
          when no rebalance is needed but you want  to  send  out
          the new device information.
     Quick  list:  add  create list_parts rebalance remove search
     set_info
                 set_min_part_hours      set_weight      validate
     write_ring
     Exit  codes:  0 = ring changed, 1 = ring did not change, 2 =
     error
DOCUMENTATION
     More in depth documentation about the swift  ring  and  also
     OpenStack    Swift    as   a   whole   can   be   found   at
     http://swift.openstack.org/overview_ring.html,
     http://swift.openstack.org/admin_guide.html#managing-the-
     rings and http://swift.openstack.org
OpenStack             Last change: 8/26/2011                    4
ATTRIBUTES
     See  attributes(5)  for  descriptions   of   the   following
     attributes:
     |ATTRIBUTE TYPE |   ATTRIBUTE VALUE     |
     |Availability   | cloud/openstack/swift |
     |Stability      | Uncommitted           |
NOTES
     This   software   was   built   from   source  available  at
     https://java.net/projects/solaris-userland.   The   original
     community   source   was   downloaded  from   http://launch-
     pad.net/swift/havana/1.10.0/+download/swift-1.10.0.tar.gz
     Further information about this software can be found on  the
     open  source community website at http://www.openstack.org/.
OpenStack             Last change: 8/26/2011                    5
