sg_write_same
(1m)
Name
sg_write_same - send the SCSI WRITE SAME command
Synopsis
sg_write_same [--10] [--16] [--32] [--anchor] [--grpnum=GN]
[--help] [--in=IF] [--lba=LBA] [--lbdata] [--num=NUM]
[--pbdata] [--timeout=TO] [--unmap] [--verbose] [--version]
[--wrprotect=WPR] [--xferlen=LEN] DEVICE
Description
SG3_UTILS SG_WRITE_SAME(8)
NAME
SYNOPSIS
DESCRIPTION
Send the SCSI WRITE SAME (10, 16 or 32 byte) command to
DEVICE. This command writes the given block NUM times to
consecutive blocks on the DEVICE starting at logical block
address LBA.
The length of the block to be written multiple times is
obtained from either the LEN argument, or the length of the
given input file IF, or by calling READ CAPACITY(16) on
DEVICE. The contents of the block to be written are obtained
from the input file IF or zeroes are used. If READ CAPAC-
ITY(16) is called (which implies IF was not given) and the
PROT_EN bit is set then an extra 8 bytes (i.e. more than
the logical block size) of 0xff are sent. If READ CAPAC-
ITY(16) fails then READ CAPACITY(10) is used to determine
the block size.
If neither --10, --16 nor --32 is given then WRITE SAME(10)
is sent unless one of the following conditions is met. If
LBA (plus NUM) exceeds 32 bits, NUM exceeds 65535, or the
--unmap option is given then WRITE SAME(16) is sent. The
--10, --16 and --32 options are mutually exclusive.
In SBC-3 revision 26 the UNMAP and ANCHOR bits were added to
the WRITE SAME (10) command. Since the UNMAP bit has been in
WRITE SAME (16) and WRITE SAME (32) since SBC-3 revision 18,
the lower of the two (i.e. WRITE SAME (16)) is the default
when the --unmap option is given. To send WRITE SAME (10)
use the --10 option.
Take care: The WRITE SAME(10, 16 and 32) commands interpret
a NUM of zero as write to the end of DEVICE. This utility
defaults NUM to 1 . The WRITE SAME commands have no IMMED
bit so if NUM is large (or zero) then an invocation of this
utility could take a long time, potentially as long as a
FORMAT UNIT command. In such situations the command timeout
value TO may need to be increased from its default value of
60 seconds. In SBC-3 revision 26 the WSNZ (write same no
zero) bit was added to the Block Limits VPD page [0xB0]. If
set the WRITE SAME commands will not accept a NUM of zero.
The same SBC-3 revision added the "Maximum Write Same
Length" field to the Block Limits VPD page.
sg3_utils-1.33 Last change: November 2011 1
The Logical Block Provisioning VPD page [0xB2] contains the
LBWS and LBW10 bits. If LBWS is set then WRITE SAME (16)
supports the UNMAP bit. If LBWS10 is set then WRITE SAME
(10) supports the UNMAP bit. If either LBWS or LBWS10 is set
and the WRITE SAME (32) is supported then WRITE SAME (32)
supports the UNMAP bit. This is as of SBC-3 revision 26.
As a precaution against an accidental 'sg_write_same
/dev/sda' (for example) overwriting LBA 0 on /dev/sda with
zeroes, at least one of the --in=IF, --lba=LBA or --num=NUM
options must be given. Obviously this utility can destroy a
lot of user data so check the options carefully.
OPTIONS
Arguments to long options are mandatory for short options as
well.
-R, --10
send a SCSI WRITE SAME (10) command to DEVICE. The
ability to set the --unmap (and --anchor) options to
this command was added in SBC-3 revision 26.
-S, --16
send a SCSI WRITE SAME (16) command to DEVICE.
-T, --32
send a SCSI WRITE SAME (32) command to DEVICE.
-a, --anchor
sets the ANCHOR bit in the cdb. Introduced in SBC-3
revision 22. That draft requires the --unmap option to
also be specified.
-g, --grpnum=GN
sets the 'Group number' field to GN. Defaults to a
value of zero. GN should be a value between 0 and 31.
-h, --help
output the usage message then exit.
-i, --in=IF
read data (binary) from file named IF and use it as the
data out buffer for the SCSI WRITE SAME command. The
length of the data out buffer is --xferlen=LEN or, if
that is not given, the length of the IF file. If IF is
"-" then stdin is read. If this option is not given
then 0x00 bytes are used as fill with the length of the
data out buffer obtained from --xferlen=LEN or by call-
ing READ CAPACITY(16 or 10). If the response to READ
CAPACITY(16) has the PROT_EN bit set then data out
buffer size is modified accordingly with the last 8
bytes set to 0xff.
sg3_utils-1.33 Last change: November 2011 2
-l, --lba=LBA
where LBA is the logical block address to start the
WRITE SAME command. Defaults to lba 0 which is a dan-
gerous block to overwrite on a disk that is in use.
Assumed to be in decimal unless prefixed with '0x' or
has a trailing 'h'.
-L, --lbdata
sets the LBDATA bit in the WRITE SAME cdb.
-n, --num=NUM
where NUM is the number of blocks, starting at LBA, to
write the data out buffer to. The default value for NUM
is 1. The value corresponds to the 'Number of logical
blocks' field in the WRITE SAME cdb. Note that a value
of 0 in NUM is interpreted as write the data out buffer
on every block starting at LBA to the end of the
DEVICE.
-P, --pbdata
sets the PBDATA bit in the WRITE SAME cdb.
-t, --timeout=TO
where TO is the command timeout value in seconds. The
default value is 60 seconds. If NUM is large (or zero)
a WRITE SAME command may require considerably more time
than 60 seconds to complete.
-U, --unmap
sets the UNMAP bit in the WRITE SAME(10, 16 and 32)
cdb. See UNMAP section below.
-v, --verbose
increase the degree of verbosity (debug messages).
-V, --version
output version string then exit.
-w, --wrprotect=WPR
sets the "Write protect" field in the WRITE SAME cdb to
WPR. The default value is zero. WPR should be a value
between 0 and 7. When WPR is 1 or greater, and the
disk's protection type is 1 or greater, then 8 extra
bytes of protection information are expected or gener-
ated (to place in the commmand's data out buffer).
-x, --xferlen=LEN
where LEN is the data out buffer length. Defaults to
the length of the IF file or, if that is not given,
then the READ CAPACITY(16 or 10) command is used to
find the 'Logical block length in bytes'. That figure
may be increased by 8 bytes if the DEVICE's protection
sg3_utils-1.33 Last change: November 2011 3
type is 1 or greater and the WRPROTECT field (see
--wrprotect=WPR) is 1 or greater. If both this option
and the IF option are given and LEN exceeds the length
of the IF file then LEN is the data out buffer length
with zeroes used as pad bytes.
UNMAP
Logical block provisioning is a new term introduced in SBC-3
revision 25 for the ability to mark blocks as unused. It is
closely related to the ATA DATA SET MANAGEMENT command with
the "Trim" bit set. For large storage arrays, it is a way to
provision less physical storage than the READ CAPACITY com-
mand reports is available, potentially allocating more phys-
ical storage when WRITE commands require it. For flash mem-
ory it is a way of potentially saving power (and perhaps
access time) when it is known large sections (or almost all)
of the flash memory is not in use.
Support for logical block provisioning is indicated by the
LBPME bit being set in the READ CAPACITY(16) command
response (see the sg_readcap utility). That implies at
least one of the UNMAP or WRITE SAME(16) commands is imple-
mented. If the UNMAP command is implemented then the "Maxi-
mum unmap LBA count" and "Maximum unmap block descriptor
count" fields in the Block Limits VPD page should both be
greater than zero. The READ CAPACITY(16) command response
also contains a LBPRZ bit which if set means that if
unmapped blocks are read then zeroes will be returned for
the data (and if protection information is active, 0xff
bytes are returned for that). In SBC-3 revision 27 the same
LBPRZ bit was added to the Logical Block Provisioning VPD
page.
In SBC-3 revision 25 the LBPU and ANC_SUP bits where added
to the Logical Block Provisioning VPD page. When LBPU is set
it indicates that the device supports the UNMAP command (see
the sg_unmap utility). When the ANC_SUP bit is set it indi-
cates the device supports anchored LBAs.
When the UNMAP bit is set in the cdb then the data out
buffer is also sent. Additionally the data section of that
data out buffer should be full of 0x0 bytes while the data
protection block, 8 bytes at the end if present, should be
set to 0xff bytes. If these conditions are not met and the
LBPRZ bit is set then the UNMAP bit is ignored and the data
out buffer is written to the DEVICE as if the UNMAP bit was
zero. In the absence of the --in=IF option, this utility
will attempt build a data out buffer that meets the require-
ments for the UNMAP bit in the cdb to be acted on by the
DEVICE.
sg3_utils-1.33 Last change: November 2011 4
Logical blocks may also be unmapped by the SCSI UNMAP and
FORMAT UNIT commands (see the sg_unmap and sg_format utili-
ties).
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | system/storage/sg3_utils |
|Stability | Uncommitted |
NOTES
Various numeric arguments (e.g. LBA) may include multiplica-
tive suffixes or be given in hexadecimal. See the "NUMERIC
ARGUMENTS" section in the sg3_utils(8) man page.
EXIT STATUS
The exit status of sg_write_same is 0 when it is successful.
Otherwise see the sg3_utils(8) man page.
EXAMPLES
One simple usage is to write blocks of zero from (and
including) a given LBA:
sg_write_same --lba=0x1234 --num=63 /dev/sdc
Since --xferlen=LEN has not been given, then this utility
will call the READ CAPACITY command on /dev/sdc to determine
the number of bytes in a logical block. Let us assume that
is 512 bytes. Since --in=IF is not given a block of zeroes
is assumed. So 63 blocks of zeroes (each block containing
512 bytes) will be written from (and including) LBA 0x1234 .
Note that only one block of zeroes is passed to the SCSI
WRITE SAME command in the data out buffer (as required by
SBC-3).
A similar example follows but in this case the blocks are
"unmapped" ("trimmed" in ATA speak) rather than zeroed:
sg_write_same --unmap -L 0x1234 -n 63 /dev/sdc
Note that if the LBPRZ bit in the READ CAPACITY(16) response
is set (i.e. LPPRZ is an acronym for logical block provi-
sioning read zeroes) then these two examples do the same
thing, at least seen from the point of view of subsequent
reads.
sg3_utils-1.33 Last change: November 2011 5
This utility can also be used to write protection informa-
tion (PI) on disks formatted with a protection type greater
than zero. PI is 8 bytes of extra data appended to the user
data of a logical block: the first two bytes are a CRC (the
"guard"), the next two bytes are the "application tag" and
the last four bytes are the "reference tag". With protection
types 1 and 2 if the application tag is 0xffff then the
guard should not be checked (against the user data).
In this example we assume the logical block size (of the
user data) is 512 bytes and the disk has been formatted with
protection type 1. Since we are going to modify LBA 2468
then we take a copy of it first:
dd if=/dev/sdb skip=2468 bs=512 of=2468.bin count=1
The following command line sets the user data to zeroes and
the PI to 8 0xFF bytes on LBA 2468:
sg_write_same --lba=2468 /dev/sdb
Reading back that block should be successful because the
application tag is 0xffff which suppresses the guard (CRC)
check (which would otherwise be wrong):
dd if=/dev/sdb skip=2468 bs=512 of=/dev/null count=1
Now an attempt is made to create a binary file with zeroes
in the user data, 0x0000 in the application tag and 0xff
bytes in the other two PI fields. It is awkward to create
0xff bytes in a file (in Unix) as the "tr" command below
shows:
dd if=/dev/zero bs=1 count=512 of=ud.bin
tr "\000" "\377" < /dev/zero | dd bs=1 of=ff_s.bin count=8
cat ud.bin ff_s.bin > lb.bin
dd if=/dev/zero bs=1 count=2 seek=514 conv=notrunc
of=lb.bin
The resulting file can be viewed with 'hexdump -C lb.bin'
and should contain 520 bytes. Now that file can be written
to LBA 2468 as follows:
sg_write_same --lba=2468 wrprotect=3 --in=lb.bin /dev/sdb
Note the --wrprotect=3 rather than being set to 1, since we
want the WRITE SAME command to succeed even though the PI
data now indicates the user data is corrupted. When an
attempt is made to read the LBA, an error should occur:
sg3_utils-1.33 Last change: November 2011 6
dd errors are not very expressive, if dmesg is checked there
should be a line something like this: "[sdb] Add. Sense:
Logical block guard check failed". The block can be cor-
rected by doing a "sg_write_same --lba=1234 /dev/sdb" again
or restoring the original contents of that LBA:
dd if=2468.bin bs=512 seek=2468 of=/dev/sdb conv=notrunc
count=1
Hopefully the dd command would never try to truncate the
output file when it is a block device.
AUTHORS
Written by Douglas Gilbert.
REPORTING BUGS
Report bugs to <dgilbert at interlog dot com>.
COPYRIGHT
Copyright (C) 2009-2011 Douglas Gilbert
This software is distributed under a FreeBSD license. There
is NO warranty; not even for MERCHANTABILITY or FITNESS FOR
A PARTICULAR PURPOSE.
SEE ALSO
sg_format,sg_get_lba_status,sg_read-
cap,sg_vpd,sg_unmap(sg3_utils)
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from
http://sg.danny.cz/sg/p/sg3_utils-1.33.tgz
Further information about this software can be found on the
open source community website at
http://sg.danny.cz/sg/sg3_utils.html.
sg3_utils-1.33 Last change: November 2011 7
