man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
pthread.h(3HEAD)
Name
pthread.h, pthread - threads
Synopsis
#include <pthread.h>
Description
The <pthread.h> header defines the following symbols:
PTHREAD_BARRIER_SERIAL_THREAD
PTHREAD_CANCEL_ASYNCHRONOUS
PTHREAD_CANCEL_ENABLE
PTHREAD_CANCEL_DEFERRED
PTHREAD_CANCEL_DISABLE
PTHREAD_CANCELED
PTHREAD_COND_INITIALIZER
PTHREAD_CREATE_DETACHED
PTHREAD_CREATE_JOINABLE
PTHREAD_EXPLICIT_SCHED
PTHREAD_INHERIT_SCHED
PTHREAD_MUTEX_DEFAULT
PTHREAD_MUTEX_ERRORCHECK
PTHREAD_MUTEX_INITIALIZER
PTHREAD_MUTEX_NORMAL
PTHREAD_MUTEX_RECURSIVE
PTHREAD_MUTEX_ROBUST
PTHREAD_MUTEX_STALLED
PTHREAD_ONCE_INIT
PTHREAD_PRIO_INHERIT
PTHREAD_PRIO_NONE
PTHREAD_PRIO_PROTECT
PTHREAD_PROCESS_SHARED
PTHREAD_PROCESS_PRIVATE
PTHREAD_RWLOCK_INITIALIZER
PTHREAD_SCOPE_PROCESS
PTHREAD_SCOPE_SYSTEM
The types listed below are defined as described in <sys/types.h>. See types.h(3HEAD).
pthread_attr_t
pthread_barrier_t
pthread_barrierattr_t
pthread_cond_t
pthread_condattr_t
pthread_key_t
pthread_mutex_t
pthread_mutexattr_t
pthread_once_t
pthread_rwlock_t
pthread_rwlockattr_t
pthread_spinlock_t
pthread_t
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
sched.h(3HEAD), time.h(3HEAD), types.h(3HEAD), pthread_attr_getguardsize(3C), pthread_attr_init(3C), pthread_attr_setscope(3C), pthread_cancel(3C), pthread_cleanup_pop(3C), pthread_cond_init(3C) , pthread_cond_signal(3C), pthread_cond_wait(3C), pthread_condattr_init(3C), pthread_create(3C), pthread_detach(3C), pthread_equal(3C), pthread_exit(3C), pthread_getconcurrency(3C), pthread_getschedparam (3C), pthread_join(3C), pthread_key_create(3C), pthread_key_delete(3C), pthread_mutex_consistent(3C), pthread_mutex_init(3C) , pthread_mutex_lock(3C), pthread_mutex_setprioceiling(3C), pthread_mutexattr_getrobust(3C), pthread_mutexattr_gettype(3C), pthread_mutexattr_getprotocol (3C), pthread_mutexattr_init(3C), pthread_once(3C), pthread_rwlock_init(3C), pthread_rwlock_rdlock(3C), pthread_rwlock_unlock(3C) , pthread_rwlock_wrlock(3C), pthread_rwlockattr_getpshared(3C), pthread_rwlockattr_init(3C), pthread_self(3C), pthread_setcancelstate(3C) , pthread_setspecific(3C), attributes (5), standards(5)
