man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
statvfs.h(3HEAD)
Name
statvfs.h, statvfs - VFS File System information structure
Synopsis
#include <sys/statvfs.h>
Description
The <sys/statvfs.h> header defines the statvfs structure, which includes the following members:
unsigned long f_bsize     /* file system block
                             size */
unsigned long f_frsize    /* fundamental file system block
                             size */
fsblkcnt_t    f_blocks    /* total number of blocks on file
                             system in units of f_frsize */
fsblkcnt_t    f_bfree     /* total number of free blocks */
fsblkcnt_t    f_bavail    /* number of free blocks available
                             to non-privileged process */
fsfilcnt_t    f_files     /* total number of file serial
                             numbers */
fsfilcnt_t    f_ffree     /* total number of free file serial
                             numbers */
fsfilcnt_t    f_favail    /* number of file serial numbers
                             available to non-privileged
unsigned long f_fsid      /* process file system ID */
unsigned long f_flag      /* bit mask of f_flag values */
unsigned long f_namemax   /* maximum filename length */
The fsblkcnt_t and fsfilcnt_t types are defined as described in <sys/types.h>. See types.h(3HEAD).
The following flags for the f_flag member are defined:
ST_RDONLY
read-only file system
ST_NOSUID
does not support setuid()/setgid() semantics
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
statvfs(2), types.h(3HEAD), attributes(5), standards(5)
