man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
wordexp.h(3HEAD)
Name
wordexp.h, wordexp - word-expansion types
Synopsis
#include <wordexp.h>
Description
The <wordexp.h> header defines the structures and symbolic constants used by the wordexp() and wordfree() functions. See wordexp (3C).
The structure type wordexp_t contains the following members:
size_t we_wordc        /* count of words matched by words */
char   **we_wordv      /* pointer to list of expanded words */
size_t we_offs         /* slots to reserve at the beginning
                          of we_wordv */
The flags argument to the wordexp() function is the bitwise-inclusive OR of the following flags:
WRDE_APPEND
Append words to those previously generated.
WRDE_DOOFFS
Number of null pointers to prepend to we_wordv.
WRDE_NOCMD
Fail if command substitution is requested.
WRDE_REUSE
The pwordexp argument was passed to a previous successful call to wordexp(), and has not been passed to wordfree(). The result is the same as if the application had called wordfree() and then called wordexp() without WRDE_REUSE.
WRDE_SHOWERR
Do not redirect stderr to /dev/null.
WRDE_UNDEF
Report error on an attempt to expand an undefined shell variable.
The following constants are defined as error return values:
WRDE_BADCHAR
One of the unquoted characters—<newline>, '|', '&', ';', '<', '>', '(', ')', '{', '}'—appears in words in an inappropriate context.
WRDE_BADVAL
Reference to undefined shell variable when WRDE_UNDEF is set in flags.
WRDE_CMDSUB
Command substitution requested when WRDE_NOCMD was set in flags.
WRDE_NOSPACE
Attempt to allocate memory failed.
WRDE_NOSYS
Reserved.
WRDE_SYNTAX
Shell syntax error, such as unbalanced parentheses or unterminated string.
The <wordexp.h> header defines the following type:
size_t
As described in <stddef.h>.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
wordexp(3C), attributes(5) , standards(5)
Previous
Next
