man pages section 3: Basic Library Functions
Exit Print View
Updated: July 2014
aio_return(3C)
Name
aio_return - retrieve return status of an asynchronous I/O operation
Synopsis
#include <aio.h>
ssize_t aio_return(struct aiocb *aiocbp);
Description
The aio_return() function returns the return status associated with the aiocb structure referenced by the aiocbp argument. The return status for an asynchronous I/O operation is the value that would be returned by the corresponding read(2), write(2), or fsync(3C) function call. If the error status for the operation is equal to EINPROGRESS, then the return status for the operation is undefined. The aio_return() function may be called exactly once to retrieve the return status of a given asynchronous operation; thereafter, if the same aiocb structure is used in a call to aio_return() or aio_error(3C), an error may be returned. When the aiocb structure referred to by aiocbp is used to submit another asynchronous operation, then aio_return() may be successfully used to retrieve the return status of that operation.
Return Values
If the asynchronous I/O operation has completed, then the return status, as described for read(2), write(2), and fsync(3C), is returned. If the asynchronous I/O operation has not yet completed, the results of aio_return() are undefined.
Errors
The aio_return() function will fail if:
EINVAL
The aiocbp argument does not refer to an asynchronous operation whose return status has not yet been retrieved.
ENOSYS
The aio_return() function is not supported by the system.
Usage
The aio_return() function has a transitional interface for 64-bit file offsets. See lf64(5).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Async-Signal-Safe
Standard
See also
close(2), exec(2), exit(2), fork(2), lseek(2), read(2), write(2), fsync(3C), aio.h(3HEAD), signal.h(3HEAD), aio_cancel(3C), aio_fsync(3C), aio_read(3C), lio_listio(3C), attributes(5), lf64(5), standards(5)
