man pages section 3: Basic Library Functions
Exit Print View
Updated: July 2014
door_info(3C)
Name
door_info - return information associated with a door descriptor
Synopsis
cc –mt [ flag... ] file... [ library... ]
#include <door.h>
int door_info(int d, struct door_info *info);
Description
The door_info() function returns information associated with a door descriptor. It obtains information about the door descriptor d and places the information that is relevant to the door in the structure pointed to by the info argument.
The door_info structure pointed to by the info argument contains the following members:
pid_t           di_target;      /* door server pid */
door_ptr_t      di_proc;        /* server function */
door_ptr_t      di_data;        /* data cookie for invocation */
door_attr_t     di_attributes;  /* door attributes */
door_id_t       di_uniquifier;  /* unique id among all doors */
The di_target member is the process ID of the door server, or −1 if the door server process has exited.
The values for di_attributes may be composed of the following:
DOOR_LOCAL
The door descriptor refers to a service procedure in this process.
DOOR_UNREF
The door has requested notification when all but the last reference has gone away.
DOOR_UNREF_MULTI
Similar to DOOR_UNREF, except multiple unreferenced notifications may be delivered for this door.
DOOR_IS_UNREF
There is currently only one descriptor referring to the door.
DOOR_REFUSE_DESC
The door refuses any attempt to door_call(3C) it with argument descriptors.
DOOR_NO_CANCEL
Clients who abort a door_call(3C) call on this door will not cause the cancellation(5) of the server thread handling the request.
DOOR_REVOKED
The door descriptor refers to a door that has been revoked.
DOOR_PRIVATE
The door has a separate pool of server threads associated with it.
The di_proc and di_data members are returned as door_ptr_t objects rather than void * pointers to allow clients and servers to interoperate in environments where the pointer sizes may vary in size (for example, 32-bit clients and 64-bit servers). Each door has a system-wide unique number associated with it that is set when the door is created by door_create(). This number is returned in di_uniquifier.
Return Values
Upon successful completion, 0 is returned. Otherwise, −1 is returned and errno is set to indicate the error.
Errors
The door_info() function will fail if:
EFAULT
The address of argument info is an invalid address.
EBADF
d is not a door descriptor.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
all
Availability
system/core-os
Interface Stability
Committed
MT-Level
Safe
See also
door_bind(3C), door_call(3C), door_create(3C), door_server_create(3C), attributes(5), cancellation(5)
