man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
dat_evd_post_se(3DAT)
Name
dat_evd_post_se - post Software event to the Event Dispatcher event queue
Synopsis
cc [ flag… ] file–ldat [ library… ]
#include <dat/udat.h>
DAT_RETURN
    dat_evd_post_se(
    IN        DAT_EVD_HANDLE    evd_handle,
    IN const  DAT_EVENT         *event
Parameters
evd_handle
Handle for an instance of the Event Dispatcher
event
A pointer to a Consumer created Software Event.
Description
The dat_evd_post_se() function posts Software events to the Event Dispatcher event queue. This is analogous to event arrival on the Event Dispatcher software Event Stream. The event that the Consumer provides adheres to the event format as defined in <dat.h>. The first element in the event provides the type of the event (DAT_EVENT_TYPE_SOFTWARE); the rest provide the event-type-specific parameters. These parameters are opaque to a Provider. Allocation and release of the memory referenced by the event pointer in a software event are the Consumer's responsibility.
There is no ordering between events from different Event Streams. All the synchronization issues between multiple Consumer contexts trying to post events to an Event Dispatcher instance simultaneously are left to a Consumer.
If the event queue is full, the operation is completed unsuccessfully and returns DAT_QUEUE_FULL. The event is not queued. The queue overflow condition does takes place and, therefore, the asynchronous Event Dispatcher is not effected.
Return Values
DAT_SUCCESS
The operation was successful.
DAT_INVALID_HANDLE
The evd_handle parameter is invalid.
DAT_INVALID_PARAMETER
The event parameter is invalid.
DAT_QUEUE_FULL
The Event Dispatcher queue is full.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Unsafe
Standard
uDAPL, 1.1, 1.2
See Also
libdat(3LIB), attributes(5)
