man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
di_path_prop_lookup_bytes(3DEVINFO)
Name
di_path_prop_lookup_bytes, di_path_prop_lookup_int64s, di_path_prop_lookup_ints, di_path_prop_lookup_strings - search for a path property
Synopsis
cc [ flag... ] file... –ldevinfo [ library... ]
#include <libdevinfo.h>
int di_path_prop_lookup_bytes(di_path_t path,
     const char *prop_name);
int di_path_prop_lookup_int64s(di_path_t path,
int di_path_prop_lookup_ints(di_path_t path,
     const char *prop_name, char **prop_data);
int di_path_prop_lookup_strings(di_path_t path,
Parameters
path
The handle to a path node in a di_init(3DEVINFO).
prop_name
The name of property for which to search.
prop_data
For di_path_prop_lookup_bytes(), the address to a pointer to an array of unsigned characters containing the property data.
For di_path_prop_lookup_int64(), the address to a pointer to an array of 64-bit integers containing the property data.
For di_path_prop_lookup_ints(), the address to a pointer to an array of integers containing the property data.
For di_path_prop_lookup_strings(), the address to a pointer to a buffer containing a concatenation of null-terminated strings containing the property data.
Description
These functions return the value of a known property name and type.
All memory allocated by these functions is managed by the library and must not be freed by the caller.
Return Values
If the property is found, the number of entries in prop_data is returned. Otherwise, -1 is returned and errno is set to indicate the error.
Errors
These functions will fail if:
EINVAL
One of the arguments is invalid.
ENOTSUP
The snapshot contains no property information.
ENXIO
The path property does not exist.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See Also
di_init(3DEVINFO), libdevinfo(3LIB) , attributes(5)
Writing Device Drivers for Oracle Solaris 11.2
