man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
di_prop_next(3DEVINFO)
Name
di_prop_next - libdevinfo property traversal function
Synopsis
cc [ flag... ] file... –ldevinfo [ library... ]
#include <libdevinfo.h>
di_prop_t di_prop_next(di_node_t node, di_prop_t prop);
Parameters
node
Handle to a device node.
prop
Handle to a property.
Description
The di_prop_next() function returns a handle to the next property on the property list. If prop is DI_PROP_NIL, the handle to the first property is returned.
Return Values
Upon successful completion, di_prop_next() returns a handle. Otherwise DI_PROP_NIL is returned and errno is set to indicate the error.
Errors
The di_prop_next() function will fail if:
EINVAL
Invalid argument.
ENOTSUP
The snapshot does not contain property information.
ENXIO
There are no more properties.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See Also
di_init(3DEVINFO), libdevinfo(3LIB), attributes(5)
Writing Device Drivers for Oracle Solaris 11.2
