man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
fstyp_fini(3FSTYP)
Name
fstyp_init, fstyp_fini - initialize and finalize libfstyp handle
Synopsis
cc [ flag… ] file–lfstyp –lnvpair [ library… ]
#include <libnvpair.h>
#include <libfstyp.h>
int fstyp_init(int fd, off64_t **offset, char *module_dir,
     fstyp_handle_t *handle);
void fstyp_fini(fstyp_handle_t handle);
Parameters
fd
Open file descriptor of a block or a raw device that contains the file system to be identified.
offset
Offset from the beginning of the device where the file system is located.
module_dir
Optional location of the libfstyp modules.
handle
Opaque handle to be used with libfstyp functions.
Description
The fstyp_init() function returns a handle associated with the specified parameters. This handle should be used with all other libfstyp functions.
If module_dir is NULL, fstyp_init() looks for modules in the default location: /usr/lib/fs subdirectories. The fstyp_init() function locates libfstyp modules, but might defer loading the modules until the subsequent fstyp_ident() call.
If module_dir is other than NULL, the fstyp_init() function locates a module in the directory that is specified. If no module is found, fstyp_init fails with FSTYP_ERR_MOD_NOT_FOUND.
Modules that do not support non-zero offset can fail fstyp_init() with FSTYP_ERR_OFFSET.
The fstyp_fini() function releases all resources associated with a handle and invalidates the handle.
Return Values
The fstyp_init() function returns 0 on success and an error value on failure. See fstyp_strerror(3FSTYP).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See Also
fstyp_ident(3FSTYP), fstyp_mod_init(3FSTYP), fstyp_strerror(3FSTYP), libfstyp(3LIB), attributes(5)
