man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
fstyp_get_attr(3FSTYP)
Name
fstyp_get_attr - get file system attributes
Synopsis
cc [ flag… ] file–lfstyp –lnvpair [ library… ]
#include <libnvpair.h>
#include <libfstyp.h>
int fstyp_get_attr(fstyp_handle_t handle, nvlist_t **attrp);
Parameters
handle
Opaque handle returned by fstyp_ident(3FSTYP).
attrp
Address to which the name-pair list is returned.
Description
The fstyp_get_attr() function returns a name-value pair list of various attributes for an identified file system. This function can be called only after a successful call to fstyp_ident().
Each file system has its own set of attributes. The following attributes are generic and are returned when appropriate for a particular file system type:
gen_clean (DATA_TYPE_BOOLEAN_VALUE)
Attribute for which true and false values are allowed. A false value is returned if the file system is damaged or if the file system is not cleanly unmounted. In the latter case, fsck(1M) is required before the file system can be mounted.
gen_guid (DATA_TYPE_STRING)
Globally unique string identifier used to establish the identity of the file system.
gen_version (DATA_TYPE_STRING)
String that specifes the file system version.
gen_volume_label (DATA_TYPE_STRING)
Human-readable volume label string used to describe and/or identify the file system.
Attribute names associated with specific file systems should not start with gen_.
Return Values
The fstyp_get_attr() function returns 0 on success and an error value on failure. See fstyp_strerror(3FSTYP).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See Also
fstyp_ident(3FSTYP), fstyp_mod_init(3FSTYP), fstyp_strerror(3FSTYP), libfstyp(3LIB), attributes(5)
