man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
write_vtoc(3EXT)
Name
read_vtoc, write_vtoc - read and write a disk's VTOC
Synopsis
cc [ flag ... ] file ... –ladm [ library ... ]
#include <sys/vtoc.h>
int read_vtoc(int fd, struct vtoc *vtoc);
int write_vtoc(int fd, struct vtoc *vtoc);
int read_extvtoc(int fd, struct extvtoc *extvtoc);
int write_extvtoc(int fd, struct extvtoc *extvtoc);
Description
The read_vtoc() and read_extvtoc() functions return the VTOC (volume table of contents) structure that is stored on the disk associated with the open file descriptor fd. On disks larger than 1 TB read_extvtoc() must be used.
The write_vtoc() and write_extvtoc() function stores the VTOC structure on the disk associated with the open file descriptor fd. On disks larger then 1TB write_extvtoc() function must be used.
The fd argument refers to any slice on a raw disk.
Return Values
Upon successful completion, read_vtoc() and read_extvtoc() return a positive integer indicating the slice index associated with the open file descriptor. Otherwise, they return a negative integer indicating one of the following errors:
VT_EIO
An I/O error occurred.
VT_ENOTSUP
This operation is not supported on this disk.
VT_ERROR
An unknown error occurred.
VT_OVERFLOW
The caller attempted an operation that is illegal on the disk and may overflow the fields in the data structure.
Upon successful completion, write_vtoc() and write_extvtoc() return 0. Otherwise, they return a negative integer indicating one of the following errors:
VT_EINVAL
The VTOC contains an incorrect field.
VT_EIO
VT_ENOTSUP
VT_ERROR
VT_OVERFLOW
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Unsafe
See also
fmthard(1M), format(1M), prtvtoc(1M), ioctl(2), efi_alloc_and_init(3EXT), attributes(5) , dkio(7I)
Bugs
The write_vtoc() function cannot write a VTOC on an unlabeled disk. Use format(1M) for this purpose.
Previous
Next
