man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
pool_component_info(3POOL)
Name
pool_component_info, pool_get_owning_resource - resource pool component functions
Synopsis
cc [ flag… ] file–lpool [ library… ]
#include <pool.h>
const char *pool_component_info(pool_conf_t *conf,
     pool_component_t *component, int flags);
pool_resource_t *pool_get_owning_resource(pool_conf_t *conf,
     pool_component_t *component);
Description
Certain resources, such as processor sets, are composed of resource components. Informational and ownership attributes of resource components are made available with the pool_component_info() and pool_get_owning_resource() functions. The conf argument for each function refers to the target configuration to which the operation applies.
The pool_component_info() function returns a string describing component. The string is allocated with malloc(3C). The caller is reponsible for freeing the returned string. The flags argument is ignored.
The pool_get_owning_resource() function returns the resource currently containing component. Every component is contained by a resource.
Return Values
Upon successful completion, pool_component_info() returns a string. Otherwise it returns NULL and pool_error(3POOL) returns the pool-specific error value.
Upon successful completion, pool_get_owning_resource() returns the owning resource. Otherwise it returns NULL and pool_error() returns the pool-specific error value.
Errors
The pool_component_info() function will fail if:
POE_BADPARAM
The supplied configuration's status is not POF_VALID or the flags paramter is neither 0 or 1.
POE_INVALID_CONF
The configuration is invalid.
POE_SYSTEM
A system error has occurred. Check the system error code for more details.
The pool_get_owning_resource() function will fail if:
POE_BADPARAM
The supplied configuration's status is not POF_VALID.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
CSI
Enabled
Interface Stability
Uncommitted
MT-Level
Safe
See also
libpool(3LIB), pool_error(3POOL), attributes(5)
