man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
ptree_get_next_prop(3PICLTREE)
Name
ptree_get_first_prop, ptree_get_next_prop - get a property handle of the node
Synopsis
cc [ flag... ] file... –lpicltree [ library... ]
#include <picltree.h>
int ptree_get_first_prop(picl_nodehdl_t nodeh,
     picl_prophdl_t *proph);
int ptree_get_next_prop(picl_prophdl_t proph,
     picl_prophdl_t *nextproph);
Description
The ptree_get_first_prop() function gets the handle of the first property of the node specified by nodeh and copies it into the location specified by proph.
The ptree_get_next_prop() function gets the handle of the next property after the one specified by proph from the list of properties of the node and copies it into the location specified by nextproph.
Return Values
Upon successful completion, 0 is returned. On failure, a non-negative integer is returned to indicate an error.
PICL_STALEHANDLE is returned if the handle is no longer valid. This occurs if the PICL tree was refreshed or reinitialized.
PICL_INVALIDHANDLE is returned if the specified handle never existed.
Errors
PICL_NOTPROP
Not a property
PICL_NOTNODE
Not a node
PICL_ENDOFLIST
End of list
PICL_INVALIDHANDLE
Invalid handle
PICL_STALEHANDLE
Stale handle
PICL_FAILURE
General system failure
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
ptree_get_prop_by_name(3PICLTREE), attributes (5)
