man pages section 3: Extended Library Functions, Volume 4
Exit Print View
Updated: July 2014
volmgt_running(3VOLMGT)
Name
volmgt_running - return whether or not volume management is running
Synopsis
cc [ flag... ] file... –lvolmgt [ library... ]
#include <volmgt.h>
int volmgt_running(void);
Description
This function is obsolete. The management of removable media by the Volume Management feature, including vold, has been replaced by software that supports the Hardware Abstraction Layer (HAL). Programmatic support for HAL is through the HAL APIs, which are documented on the HAL web site. See hal(5).
volmgt_running() tells whether or not Volume Management is running.
Return Values
volmgt_running() always returns 0 indicating Volume Management (as implemented by vold) is not running.
Errors
volmgt_running() will fail, returning 0, if a stat(2) or open(2) of /dev/volctl fails, or if any of the following is true:
ENXIO
Volume Management is not running.
EINTR
An interrupt signal was detected while checking to see if Volume Management was running.
Examples
Example 1 Using volmgt_running()
To see if Volume Management is running:
if (volmgt_running() != 0) {
        (void) printf("Volume Management is running\n");
} else {
        (void) printf("Volume Management is NOT running\n");
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
MT-Safe
Interface Stability
Obsolete
See also
open(2), stat(2), volmgt_check(3VOLMGT), volmgt_inuse(3VOLMGT), attributes(5), hal(5)
Notes
Volume Management must be running for many of the Volume Management library routines to work.
