man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
audio_dev_set_description(9F)
Name
audio_dev_set_description, audio_dev_set_version, audio_dev_add_info - set human-readable information fields for an audio device
Synopsis
#include <sys/audio/audio_driver.h>
void audio_dev_set_description(audio_dev_t *adev, const char *desc);
void audio_dev_set_version(audio_dev_t *adev, const char *vers);
void audio_dev_add_info(audio_dev_t *adev, const char *info);
Parameters
adev
pointer to an audio device allocated with audio_dev_alloc(9F)
desc
a short description of the device
vers
a human-readable version for the device
info
additional human-readable details about the device
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The audio_dev_set_description() and audio_dev_version() functions set strings describing the device for applications to display this information to users.
The audio_dev_add_info() function provides more detailed information, such as codec details. Successive calls to this function are additive. Each addition will represent one line of output in any detailed device report.
The strings are copied by the framework, so drivers may use local or temporary storage for them. They must be properly terminated with null bytes. Only the ASCII character set is supported.
The supplied strings may be truncated to 16 characters by some applications.
Context
These functions may be called from user or kernel context only.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See Also
attributes(5), audio(7D) , audio_dev_alloc(9F)
