man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
csx_Parse_CISTPL_DEVICE(9F)
Name
csx_Parse_CISTPL_DEVICE, csx_Parse_CISTPL_DEVICE_A, csx_Parse_CISTPL_DEVICE_OC, csx_Parse_CISTPL_DEVICE_OA - parse Device Information tuples
Synopsis
#include <sys/pccard.h>
int32_t csx_Parse_CISTPL_DEVICE(client_handle_t ch, tuple_t *tu,
     cistpl_device_t *cd);
int32_t csx_Parse_CISTPL_DEVICE_A(client_handle_t ch, tuple_t *tu,
int32_t csx_Parse_CISTPL_DEVICE_OC(client_handle_t ch, tuple_t *tu,
int32_t csx_Parse_CISTPL_DEVICE_OA(client_handle_t ch, tuple_t *tu,
Interface Level
Solaris DDI Specific (Solaris DDI)
Parameters
ch
Client handle returned from csx_RegisterClient(9F).
tu
Pointer to a tuple_t structure (see tuple(9S)) returned by a call to csx_GetFirstTuple(9F) or csx_GetNextTuple(9F).
cd
Pointer to a cistpl_device_t structure which contains the parsed CISTPL_DEVICE, CISTPL_DEVICE_A, CISTPL_DEVICE_OC, or CISTPL_DEVICE_OA tuple information upon return from these functions, respectively.
Description
csx_Parse_CISTPL_DEVICE() and csx_Parse_CISTPL_DEVICE_A() parse the 5 volt Device Information tuples, CISTPL_DEVICE and CISTPL_DEVICE_A, respectively, into a form usable by PC Card drivers.
csx_Parse_CISTPL_DEVICE_OC() and csx_Parse_CISTPL_DEVICE_OA() parse the Other Condition Device Information tuples, CISTPL_DEVICE_OC and CISTPL_DEVICE_OA, respectively, into a form usable by PC Card drivers.
The CISTPL_DEVICE and CISTPL_DEVICE_A tuples are used to describe the card's device information, such as device speed, device size, device type, and address space layout information for Common Memory or Attribute Memory space, respectively.
The CISTPL_DEVICE_OC and CISTPL_DEVICE_OA tuples are used to describe the information about the card's device under a set of operating conditions for Common Memory or Attribute Memory space, respectively.
Structure Members
The structure members of cistpl_device_t are:
uint32_t               num_devices;    /* number of devices found */
cistpl_device_node_t   devnode[CISTPL_DEVICE_MAX_DEVICES];
The structure members of cistpl_device_node_t are:
uint32_t     flags;             /* flags specific to this device */
uint32_t     speed;             /* device speed in device
                                /*  speed code format */
uint32_t     nS_speed;          /* device speed in nS */
uint32_t     type;              /* device type */
uint32_t     size;              /* device size */
uint32_t     size_in_bytes;     /* device size in bytes */
The fields are defined as follows:
flags
This field indicates whether or not the device is writable, and describes a Vcc voltage at which the PC Card can be operated.
CISTPL_DEVICE_WPS
Write Protect Switch bit is set
Bits which are applicable only for CISTPL_DEVICE_OC and CISTPL_DEVICE_OA are:
CISTPL_DEVICE_OC_MWAIT
Use MWAIT
CISTPL_DEVICE_OC_Vcc_MASK
Mask for Vcc value
CISTPL_DEVICE_OC_Vcc5
5.0 volt operation
CISTPL_DEVICE_OC_Vcc33
3.3 volt operation
CISTPL_DEVICE_OC_VccXX
X.X volt operation
CISTPL_DEVICE_OC_VccYY
Y.Y volt operation
speed
The device speed value described in the device speed code unit. If this field is set to CISTPL_DEVICE_SPEED_SIZE_IGNORE, then the speed information will be ignored.
nS_speed
The device speed value described in nanosecond units.
size
The device size value described in the device size code unit. If this field is set to CISTPL_DEVICE_SPEED_SIZE_IGNORE, then the size information will be ignored.
size_in_bytes
The device size value described in byte units.
type
This is the device type code field which is defined as follows:
CISTPL_DEVICE_DTYPE_NULL
No device
CISTPL_DEVICE_DTYPE_ROM
Masked ROM
CISTPL_DEVICE_DTYPE_OTPROM
One Time Programmable ROM
CISTPL_DEVICE_DTYPE_EPROM
UV EPROM
CISTPL_DEVICE_DTYPE_EEPROM
EEPROM
CISTPL_DEVICE_DTYPE_FLASH
FLASH
CISTPL_DEVICE_DTYPE_SRAM
Static RAM
CISTPL_DEVICE_DTYPE_DRAM
Dynamic RAM
CISTPL_DEVICE_DTYPE_FUNCSPEC
Function-specific memory address range
CISTPL_DEVICE_DTYPE_EXTEND
Extended type follows
Return Values
CS_SUCCESS
Successful operation.
CS_BAD_HANDLE
Client handle is invalid.
CS_UNKNOWN_TUPLE
Parser does not know how to parse tuple.
CS_NO_CARD
No PC Card in socket.
CS_NO_CIS
No Card Information Structure (CIS) on PC Card.
CS_UNSUPPORTED_FUNCTION
No PCMCIA hardware installed.
Context
These functions may be called from user or kernel context.
See Also
csx_GetFirstTuple(9F), csx_GetTupleData(9F), csx_Parse_CISTPL_JEDEC_C(9F), csx_RegisterClient(9F), csx_ValidateCIS(9F), tuple(9S)
PC Card 95 Standard, PCMCIA/JEIDA
