man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
ddi_create_minor_node(9F)
Name
ddi_create_minor_node - Create a minor node for this device
Synopsis
#include <sys/stat.h>
#include <sys/sunddi.h>
int ddi_create_minor_node(dev_info_t *dip, char *name, int spec_type,
     minor_t minor_num, char *node_type, int flag);
Interface Level
Solaris DDI specific (Solaris DDI).
Parameters
dip
A pointer to the device's dev_info structure.
name
The name of this particular minor device.
spec_type
S_IFCHR or S_IFBLK for character or block minor devices respectively.
minor_num
The minor number for this particular minor device.
node_type
Any string literal that uniquely identifies the type of node. The following predefined node types are provided with this release:
DDI_NT_SERIAL
For serial ports
DDI_NT_SERIAL_MB
For on board serial ports
DDI_NT_SERIAL_DO
For dial out ports
DDI_NT_SERIAL_MB_DO
For on board dial out ports
DDI_NT_BLOCK
For hard disks
DDI_NT_BLOCK_CHAN
For hard disks with channel or target numbers
DDI_NT_CD
For CDROM drives
DDI_NT_CD_CHAN
For CDROM drives with channel or target numbers
DDI_NT_TAPE
For tape drives
DDI_NT_NET
For DLPI style 1 or style 2 network devices
DDI_NT_DISPLAY
For display devices
DDI_PSEUDO
For pseudo devices
flag
If the device is a clone device then this flag is set to CLONE_DEV else it is set to 0.
Description
ddi_create_minor_node() provides the necessary information to enable the system to create the /dev and /devices hierarchies. The name is used to create the minor name of the block or character special file under the /devices hierarchy. At-sign (@), slash (/), and space are not allowed. The spec_type specifies whether this is a block or character device. The minor_num is the minor number for the device. The node_type is used to create the names in the /dev hierarchy that refers to the names in the /devices hierarchy. See disks(1M) , ports(1M), tapes(1M) , devlinks(1M). Finally flag determines if this is a clone device or not, and what device class the node belongs to.
Return Values
ddi_create_minor_node() returns:
DDI_SUCCESS
Was able to allocate memory, create the minor data structure, and place it into the linked list of minor devices for this driver.
DDI_FAILURE
Minor node creation failed.
Context
The ddi_create_minor_node() function can be called from user context. It is typically called from attach(9E) or ioctl(9E).
Examples
Example 1 Create Data Structure Describing Minor Device with Minor Number of 0
The following example creates a data structure describing a minor device called foo which has a minor number of 0. It is of type DDI_NT_BLOCK (a block device) and it is not a clone device.
ddi_create_minor_node(dip, "foo", S_IFBLK, 0, DDI_NT_BLOCK, 0);
See also
add_drv(1M), devlinks(1M), disks(1M), drvconfig(1M), ports(1M), tapes(1M), attach(9E), ddi_remove_minor_node(9F)
Writing Device Drivers for Oracle Solaris 11.2
Notes
If the driver is for a network device (node_type DDI_NT_NET), note that the driver name will undergo the driver name constraints identified in the NOTES section of dlpi (7P). Additionally, the minor name must match the driver name for a DLPI style 2 provider. If the driver is a DLPI style 1 provider, the minor name must also match the driver name with the exception that the ppa is appended to the minor name.
Non-gld(7D)-based DLPI network streams drivers are encouraged to switch to gld (7D). Failing this, a driver that creates DLPI style-2 minor nodes must specify CLONE_DEV for its style-2 ddi_create_minor_node() nodes and use qassociate(9F). A driver that supports both style-1 and style-2 minor nodes should return DDI_FAILURE for DDI_INFO_DEVT2INSTANCE and DDI_INFO_DEVT2DEVINFO getinfo(9E) calls to style-2 minor nodes. (The correct association is already established by qassociate(9F)). A driver that only supports style-2 minor nodes can use ddi_no_info(9F) for its getinfo(9E) implementation. For drivers that do not follow these rules, the results of a modunload(1M) of the driver or a cfgadm(1M) remove of hardware controlled by the driver are undefined.
WARNING
WARNING
Drivers must remove references to GLOBAL_DEV, NODEBOUND_DEV, NODESPECIFIC_DEV, and ENUMERATED_DEV to compile under Solaris 10 and later versions.
