man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
ddi_mem_putw(9F)
Name
ddi_mem_put8, ddi_mem_put16, ddi_mem_put32, ddi_mem_put64, ddi_mem_putb, ddi_mem_putw, ddi_mem_putl, ddi_mem_putll - write data to mapped device in the memory space or allocated DMA memory
Synopsis
#include <sys/ddi.h>
#include <sys/sunddi.h>
void ddi_mem_put8(ddi_acc_handle_t handle, uint8_t *dev_addr,
     uint8_t value);
void ddi_mem_put16(ddi_acc_handle_t handle, uint16_t *dev_addr,
     uint16_t value);
void ddi_mem_put32(ddi_acc_handle_t handle, uint32_t *dev_addr,
     uint32_t value);
void ddi_mem_put64(ddi_acc_handle_t handle, uint64_t *dev_addr,
     uint64_t value);
Parameters
handle
The data access handle returned from setup calls, such as ddi_regs_map_setup(9F).
dev_addr
Base device address.
value
The data to be written to the device.
Interface Level
Solaris DDI specific (Solaris DDI). The ddi_mem_put8(), ddi_mem_put16(), ddi_mem_put32(), ddi_mem_put64(), ddi_mem_putb(), ddi_mem_putl(), ddi_mem_putll(), and ddi_mem_putw() functions are obsolete. The ddi_put8(9F) function replaces ddi_mem_put8(). The ddi_put16(9F) function replaces ddi_mem_put16(). The ddi_put32(9F) function replaces ddi_mem_put32(). The ddi_put64(9F) function replaces ddi_mem_put64 (). The ddi_put8(9F) function replaces ddi_mem_putb(). The ddi_put32(9F) function replaces ddi_mem_putl(). The ddi_put64(9F) function replaces ddi_mem_putll(). The ddi_put16(9F) function replaces ddi_mem_putw().
Description
These routines generate a write of various sizes to memory space or allocated DMA memory. The ddi_mem_put8(), ddi_mem_put16(), ddi_mem_put32(), and ddi_mem_put64() functions write 8 bits, 16 bits, 32 bits and 64 bits of data, respectively, to the device address, dev_addr, in memory space.
Each individual datum will automatically be translated to maintain a consistent view between the host and the device based on the encoded information in the data access handle. The translation may involve byte-swapping if the host and the device have incompatible endian characteristics.
Context
These functions can be called from user, kernel, or interrupt context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Obsolete
See Also
ddi_mem_get8(9F), ddi_mem_rep_get8(9F), ddi_put8(9F), ddi_put16(9F), ddi_put32(9F), ddi_put64(9F), ddi_mem_get8(9F), ddi_regs_map_setup(9F), ddi_device_acc_attr(9S)
