man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
ddi_pokes(9F)
Name
ddi_poke, ddi_poke8, ddi_poke16, ddi_poke32 , ddi_poke64, ddi_pokec, ddi_pokes, ddi_pokel, ddi_poked - write a value to a location
Synopsis
#include <sys/ddi.h>
#include <sys/sunddi.h>
int ddi_poke8(dev_info_t *dip, int8_t *addr, int8_t value);
int ddi_poke16(dev_info_t *dip, int16_t *addr, int16_t value);
int ddi_poke32(dev_info_t *dip, int32_t *addr, int32_t value);
int ddi_poke64(dev_info_t *dip, int64_t *addr, int64_t value);
Interface Level
Solaris DDI specific (Solaris DDI). The ddi_pokec(), ddi_pokes(), ddi_pokel(), and ddi_poked() functions are obsolete. Use, respectively, ddi_poke8(), ddi_poke16(), ddi_poke32 (), and ddi_poke64(), instead.
Parameters
dip
A pointer to the device's dev_info structure.
addr
Virtual address of the location to be written to.
value
Value to be written to the location.
Description
These routines cautiously attempt to write a value to a specified virtual address, using the parent nexus driver to assist in the process where necessary.
If the address is not valid, or the value cannot be written without an error occurring, an error code is returned.
These routines are most useful when first trying to establish the presence of a given device on the system in a driver's probe(9E) or attach(9E) routines.
On multiprocessing machines these routines can be extremely heavy-weight, so use the ddi_peek(9F) routines instead if possible.
Return Values
DDI_SUCCESS
The value was successfully written to the given virtual address.
DDI_FAILURE
An error occurred while trying to write to the location.
Context
These functions can be called from user, interrupt, or kernel context.
See Also
attach(9E), probe(9E), ddi_peek(9F)
Writing Device Drivers for Oracle Solaris 11.2
Notes
The functions described in this manual page previously used symbolic names which specified their data access size; the function names have been changed so they now specify a fixed-width data size. See the following table for the new name equivalents:
Previous Name
New Name
ddi_pokec
ddi_poke8
ddi_pokes
ddi_poke16
ddi_pokel
ddi_poke32
ddi_poked
ddi_poke64
