man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
ddi_removing_power(9F)
Name
ddi_removing_power - check whether DDI_SUSPEND might result in power being removed from a device
Synopsis
#include <sys/ddi.h>
#include <sys/sunddi.h>
int ddi_removing_power(dev_info_t *dip);
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The ddi_removing_power() function indicates whether a currently pending call into a driver's detach(9E) entry point with a command of DDI_SUSPEND is likely to result in power being removed from the device.
ddi_removing_power() can return true and power still not be removed from the device due to a failure to suspend and power off the system.
Parameters
The ddi_removing_power() function supports the following parameter:
dip
pointer to the device's dev_info structure
Return Values
The ddi_removing_power() function returns:
1
Power might be removed by the framework as a result of the pending DDI_SUSPEND call.
0
Power will not be removed by the framework as a result of the pending DDI_SUSPEND call.
Examples
Example 1 Protecting a Tape from Abrupt Power Removal
A tape driver that has hardware that would damage the tape if power is removed might include this code in its detach(9E) code:
int
     xxdetach(dev_info_t *dip, ddi_detach_cmd_t cmd)
          case DDI_SUSPEND:
           * We do not allow DDI_SUSPEND if power will be removed and
           * we have a device that damages tape when power is removed
           * We do support DDI_SUSPEND for Device Reconfiguration,
           * however.
             if (ddi_removing_power(dip) && xxdamages_tape(dip))
                return (DDI_FAILURE);
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See Also
attributes(5), cpr(7), attach(9E), detach(9E)
Writing Device Drivers
