man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
scsi_slave(9F)
Name
scsi_slave - utility for SCSI target drivers to establish the presence of a target
Synopsis
#include <sys/scsi/scsi.h>
int scsi_slave(struct scsi_device *devp, int (*callback)(void));
Interface Level
The scsi_slave() function is obsolete. This function has been replaced by scsi_probe(9F).
Parameters
devp
Pointer to a scsi_device(9S) structure.
callback
Pointer to a callback function, NULL_FUNC or SLEEP_FUNC.
Description
scsi_slave() checks for the presence of a SCSI device. Target drivers may use this function in their probe(9E) routines. scsi_slave() determines if the device is present by using a Test Unit Ready command followed by an Inquiry command. If scsi_slave() is successful, it will fill in the scsi_inquiry structure, which is the sd_inq member of the scsi_device(9S) structure, and return SCSI_PROBE_EXISTS. This information can be used to determine if the target driver has probed the correct SCSI device type. callback indicates what the allocator routines should do when DMA resources are not available:
NULL_FUNC
Do not wait for resources. Return a NULL pointer.
SLEEP_FUNC
Wait indefinitely for resources.
Other Values
callback points to a function which is called when resources may have become available. callback must return either 0 (indicating that it attempted to allocate resources but again failed to do so), in which case it is put back on a list to be called again later, or 1 indicating either success in allocating resources or indicating that it no longer cares for a retry.
Return Values
scsi_slave() returns:
SCSIPROBE_NOMEM
No space available for structures.
SCSIPROBE_EXISTS
Device exists and inquiry data is valid.
SCSIPROBE_NONCCS
Device exists but inquiry data is not valid.
SCSIPROBE_FAILURE
Polled command failure.
SCSIPROBE_NORESP
No response to TEST UNIT READY.
Context
scsi_slave() is normally called from the target driver's probe(9E) or attach(9E) routine. In any case, this routine should not be called from interrupt context, because it can sleep waiting for memory to be allocated.
Attributes
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Stability Level
Obsolete
See Also
attributes(5), attach(9E) , probe(9E), ddi_iopb_alloc(9F), makecom(9F), scsi_dmaget(9F), scsi_ifgetcap(9F), scsi_pktalloc(9F), scsi_poll(9F), scsi_probe(9F), scsi_device( 9S)
ANSI Small Computer System Interface-2 (SCSI-2)
Writing Device Drivers for Oracle Solaris 11.2
Notes
The scsi_slave() function is obsolete and will be discontinued in a future release. This function has been replaced by scsi_probe(9F).
