man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
sof_bypass(9F)
Name
sof_bypass - stop receiving callbacks
Synopsis
#include <sys/sockfilter.h>
void sof_bypass(sof_handle_t hdl);
Parameters
hdl
per-socket filter handle
Description
The sof_bypass() function informs the framework that the filter instance no longer wants to receive callbacks. No guarantee is made that there will not be any active callbacks when sof_bypass() returns, only that no new callbacks will be triggered.
The only callback that will triggered for a filter that has called sof_bypass() is sofop_detach(9E).
A typical use of sof_bypass() is for a filter that only needs to be active during a certain period of a socket's lifetime. Calling sof_bypass() will minimize the performance impact of the inactive filter.
Context
The sof_bypass() function can be called from any context
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/kernel
Interface Stability
Uncommitted
See Also
attributes(5), sofop_detach(9E) , sof_ops(9S)
