man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
usb_handle_remote_wakeup(9F)
Name
usb_handle_remote_wakeup - Enable or disable remote wakeup on USB devices
Synopsis
#include <sys/usb/usba.h>
int usb_handle_remote_wakeup(dev_info_t *dip, int cmd);
Interface Level
Solaris DDI specific (Solaris DDI)
Parameters
dip
Pointer to the device's dev_info structure.
cmd
Command. Either USB_REMOTE_WAKEUP_ENABLE or USB_REMOTE_WAKEUP_DISABLE.
Description
The usb_handle_remote_wakeup() function enables or disables remote wakeup on a USB device. This call can block.
Return Values
USB_SUCCESS
Remote wakeup is successfully enabled or disabled.
USB_FAILURE
Remote wakeup is not supported by the device. An internal error occurred.
Context
May be called from user or kernel context.
Examples
    uint_t *pwrstates;
    /* Hook into device's power management.  Enable remote wakeup. */
    if (usb_create_pm_components(dip, pwrstates) == USB_SUCCESS) {
            usb_handle_remote_wakeup(dip, USB_REMOTE_WAKEUP_ENABLE);
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
PCI-based systems
Interface Stability
Committed
Availability
system/io/usb
See Also
attributes(5), pm_busy_component(9F), pm_idle_component(9F), pm_lower_power(9F), pm_raise_power(9F), usb_clr_feature(9F), usb_create_pm_components(9F), usb_get_cfg(9F), usb_get_dev_data(9F), usb_register_hotplug_cbs(9F), usb_cfg_descr(9S)
