man pages section 9: DDI and DKI Kernel Functions
Exit Print View
Updated: July 2014
usb_owns_device(9F)
Name
usb_get_alt_if, usb_set_alt_if, usb_get_if_number, usb_owns_device - Get and set alternate interface values
Synopsis
#include <sys/usb/usba.h>
int usb_get_alt_if(dev_info_t *dip, uint_t interface_number,
     uint_t *alternate_number, usb_flags_t flags);
int usb_set_alt_if(dev_info_t *dip, uint_t interface_number,
     uint_t alternate_number, usb_flags_t flags,
     void (*callback)(usb_pipe_handle_t pipe_handle,
     usb_opaque_t callback_arg, int rval, usb_cb_flags_t flags),
     usb_opaque_t callback_arg);
int usb_get_if_number(dev_info_t *dip);
boolean_t usb_owns_device(dev_info_t *dip);
Interface Level
Solaris DDI specific (Solaris DDI)
Parameters
For usb_get_alt_if():
dip
Pointer to device's dev_info structure.
interface_number
Interface of the desired alternate.
alternate_number
Address where current alternate setting is returned.
flags
No flags are recognized. Reserved for future expansion.
For usb_set_alt_if():
dip
interface_number
alternate_number
Alternate interface number to be set.
flags
Only USB_FLAGS_SLEEP is recognized. Wait for completion and do not call callback.
callback
Callback handler to notify of asynchronous completion.
callback_arg
Second argument passed to callback handler.
For usb_get_if_number():
dip
For usb_owns_device():
dip
Description
USB devices can have multiple configurations, each with many interfaces. Within interfaces are alternate settings, and within alternate settings are endpoints.
Each interface within a configuration may be represented by the kernel as a device node. Only one set of device nodes (interfaces as determined by the configuration) can be active at one time.
Alternates to an interface represent different ways the kernel sees a device node. Only one alternate setting within an interface can be active (or selected) at one time. The functions presented in this man page get or set interface or alternate setting information.
The usb_get_alt_if() function requests the device to return the current alternate setting of the given interface. This function ignores the flags argument and always blocks.
The usb_set_alt_if() function requests the device to set the interface and its alternate setting as specified. Because this call changes the current device's interface and sets the new interface's mode of operation as seen by the system, the driver must insure that all pipes other than the default control pipe are closed and quiescent. To avoid contending with another driver for a different part of the device, the driver must be bound to: the entire device, the interface-association which includes the alternative interface, or to the interface whose number is interface_number.
If USB_FLAGS_SLEEP is set in flags, usb_set_alt_if() blocks until completed. Otherwise, usb_set_alt_if() returns immediately and calls the callback handler when completed.
callback is the asynchronous callback handler and takes the following arguments:
Handle of the default control pipe used to perform the request.
Callback_arg specified to usb_set_alt_if().
int rval
Request status.
usb_cb_flags_t callback_flags:
Status of the queueing operation. Can be:
USB_CB_NO_INFO - Callback was uneventful.
USB_CB_ASYNC_REQ_FAILED - Error queueing request.
USB_CB_NO_RESOURCES - Error allocating resources.
The usb_get_if_number() function returns the interface number, or USB_COMBINED_NODE or USB_DEVICE_NODE node indicating that the driver is bound to the entire device.
The usb_owns_device() function returns B_TRUE if the driver of the dip argument owns the entire device, or B_FALSE if it owns just a particular interface.
Return Values
USB_SUCCESS
Interface's alternate setting was successfully obtained.
USB_INVALID_ARGS
Pointer to alternate_number and/or dip are NULL.
USB_INVALID_CONTEXT
Called from interrupt context.
USB_FAILURE
The interface number is invalid.
An access error occurred.
USB_SUCCESS
Alternate interface was successfully set.
USB_INVALID_ARGS
dip is NULL. USB_FLAGS_SLEEP is clear and callback is NULL.
USB_INVALID_PERM
dip does not own the interface to be set.
USB_INVALID_CONTEXT
Called from interrupt context with USB_FLAGS_SLEEP specified.
USB_INVALID_PIPE
Pipe handle is NULL, invalid, or refers to a pipe that is closing or closed.
USB_FAILURE
The interface number and/or alternate setting are invalid.
Pipes were open.
USB_COMBINED_NODE if the driver is responsible for the entire active device configuration. The dip doesn't correspond to an entire physical device.
USB_DEVICE_NODE if the driver is responsible for the entire device. The dip corresponds to an entire physical device.
interface number: otherwise.
B_TRUE
Driver of the dip argument owns the entire device.
B_FALSE
Driver of the dip argument owns only the current interface.
Context
The usb_get_if_number() and usb_owns_device() functions may be called from user or kernel context.
The usb_set_alt_if() function may always be called from user or kernel context. It may be called from interrupt context only if USB_FLAGS_SLEEP is not set in flags. If the USB_CB_ASYNC_REQ_FAILED bit is clear in usb_cb_flags_t, the callback, if supplied, can block because it is executing in kernel context. Otherwise the callback cannot block. See usb_callback_flags(9S) for more information on callbacks.
The usb_get_alt_if() function may be called from user or kernel context.
Examples
/* Change alternate setting of interface 0.  Wait for completion. */
if (usb_set_alt_if(
    dip, 0, new_alternate_setting_num, USB_FLAGS_SLEEP, NULL, 0) !=
    USB_SUCCESS) {
        cmn_err (CE_WARN,
            "%s%d: Error setting alternate setting on pipe",
            ddi_driver_name(dip), ddi_get_instance(dip));
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
PCI-based systems
Interface Stability
Committed
Availability
system/io/usb
See Also
attributes(5), usb_pipe_ctrl_xfer(9F), usb_get_dev_data(9F), usb_get_string_descr(9F), usb_get_cfg(9F)
