Skip Navigation Links
Exit Print View
Sun Server X4-2L HTML Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Getting the Latest Software and Firmware
About This Documentation
Related Documentation
Feedback
Access to Oarcle Support
Installation
About the Installation Procedure
Installation Procedure Overview
Preparing for Server Installation
Server Physical Specifications
Space Requirements
Electrical Power Requirements
Environmental Requirements
Ventilation and Cooling
Agency Compliance
Shipping Inventory
Tools and Equipment Needed for Installation
ESD and Safety Precautions
Optional Component Installation
About Server Features and Components
Server Components
Front Panel Status Indicators, Connectors, and Drives
Back Panel Status Indicators, Connectors, Drives, and PCIe Slots
Server Management Software Overview
Getting Server Firmware and Software Updates
Firmware and Software Access Options
Software Releases
Getting Firmware and Software From MOS or PMR
Installing Updates Using Other Methods
Installing the Server Into a Rack
Installation Prerequisites
Rack Requirements
Safety Precautions When Rackmounting the Server
Rackmount Kit Contents
Stabilize the Rack for Installation
Install Mounting Brackets
Mark the Rackmount Location
Attach Tool-less Slide-Rail Assemblies
Install the Server Into the Slide-Rail Assemblies
Install the Second-Generation Cable Management Arm
Remove the Second-Generation Cable Management Arm
Install the First-Generation Cable Management Arm
Verify Operation of Slide-Rails and CMA
Cabling the Server
Rear Cable Connections and Ports
Ethernet Ports
Attaching Data Cables to the Server
Connect the Data Cables
Connecting Power Cords to the Server
Connect the Power Cords
Connecting to Oracle ILOM
Oracle ILOM Hardware and Interfaces
Network Defaults
Logging In to Oracle ILOM Using a Local Serial Connection
Logging In to Oracle ILOM Using a Remote Ethernet Connection
Accessing the Host Console Through Oracle ILOM
Troubleshooting the Service Processor Connection
Setting Up Software and Firmware Using Oracle System Assistant
Accessing Oracle System Assistant
Set Up Software and Firmware Using Oracle System Assistant
Setting Up an Operating System and Drivers
Configuring Server Drives for OS Installation
RAID Configuration Tools
RAID Configuration Requirements
Configuring Storage Drives Into RAID Volumes Using Oracle System Assistant
Configuring RAID Using the BIOS RAID Configuration Utilities
Configuring the Preinstalled Oracle Solaris 11.1 Operating System
Preinstalled Oracle Solaris 11.1 Image BIOS Boot Mode Restriction
Preinstalled Operating System RAID Limitations
Operating System Options
Oracle Solaris 11.1 Configuration Worksheet
Configure the Preinstalled Oracle Solaris 11.1 Operating System
Oracle Solaris 11.1 Operating System Documentation
Configuring the Preinstalled Oracle Linux 6. x Operating System
Preinstalled Oracle Linux Image BIOS Boot Mode Restriction
Oracle Linux 6.x Configuration Worksheet
Configure the Preinstalled Oracle Linux 6.x Operating System
Registering Oracle Linux and Activating Automatic Update
Oracle Linux 6.x Operating System Documentation
Configuring the Preinstalled Oracle VM 3.2 Software
Preinstalled Oracle VM Image BIOS Boot Mode Restriction
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Oracle VM Server Configuration Worksheet
Configure the Preinstalled Oracle VM Server
Updating Oracle VM Software
Oracle VM Documentation
Controlling System Power
Powering Off the Server for Orderly Shutdown
Powering Off the Server for Immediate Shutdown
Reset the Server
Troubleshooting Installation Issues
Installation Troubleshooting
Technical Support Information Worksheet
Locating the System Serial Number
Site Planning Checklists
Preparation Checklists
Oracle Solaris Installation
About Oracle Solaris Operating System Installs
Oracle Solaris OS Installation Task Map
Supported Operating Systems
Selecting the Console Display Option
Selecting the Boot Media Option
Selecting the Installation Target Option
Oracle Solaris OS Installation Options
Oracle System Assistant Overview
Preparing to Install the Operating System
Setting Up BIOS
Configuring RAID
Installing the Oracle Solaris Operating System
Before You Begin
Installing Oracle Solaris on a Single System Using Oracle System Assistant
Installing the Oracle Solaris 10 or 11 Operating System on a Single System Using Media
Oracle VM Installation
About Oracle VM Installs
Oracle VM Installation Task Map
Supported Oracle VM Software
Oracle VM Installation Options
Preparing to Install Oracle VM
Verify the BIOS Factory Defaults
Disable VT-d and SR-IOV in BIOS
Configuring RAID
Installing Oracle VM
Before You Begin
Installing Oracle VM on a Single System Using Oracle System Assistant
Installing Oracle VM on a Single System Using Media
Post Installation Tasks for Oracle VM
Configuring Network Interfaces
NIC Connectors
Linux Installation
About Linux Operating System Installs
Supported Linux Operating Systems
Oracle Unbreakable Enterprise Kernel for Linux
Linux OS Installation Options
Setting Up BIOS
Configuring RAID
Installing a Linux Operating System
Installing a Linux OS on a Single System Using Oracle System Assistant
Installing Oracle Linux on a Single System Using Media
Installing Red Hat Enterprise Linux on a Single System Using Media
Installing SUSE Linux Enterprise Server on a Single System Using Media
NIC Connectors
Windows Installation
About Microsoft Windows Server Operating System Installs
Windows OS Installation Task Map
Supported Windows Operating Systems
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
Windows OS Installation Options
Setting Up BIOS
Configuring RAID
Installing a Windows Server Operating System
Before You Begin
Installing Windows Server on a Single System Using Oracle System Assistant
Installing Windows Server on a Single System Using Media
Post Installation Tasks for Windows Server
Supplemental Software Component Options
Installing Device Drivers and Supplemental Software
Configuring Intel NIC Teaming
VMware ESXi Installation
About VMware ESXi Installs
VMware ESXi Installation Task Map
Supported VMware ESXi Software
VMware ESXi Installation Options
Preparing to Install VMware ESXi
Setting Up BIOS
Configuring the VMware ESXi 5.0 Software or the Server Hardware to Support Network Connections
Configuring RAID
Installing VMware ESXi
Before You Begin
Installing VMware ESXi on a Single System Using Media
Post Installation Tasks for VMware ESXi
Configure Network Adapter Settings
Determine the MAC Address of a Connected Server Network Port
Update the VMware ESXi Software
Manage VMware ESXi Resources
NIC Connectors
Service
About the Sun Server X4-2L
Product Description
About Controls and Connectors
About Server and Component Status Indicators
About System Components
Troubleshooting the Server
Service Troubleshooting Task List
Diagnostic Tools
Gather Service Information
Locate the Server Serial Number
Inspecting the System
Preparing for Service
Safety Precautions
Safety Symbols
Electrostatic Discharge Safety
FRU TLI Auto-Update
Required Tools
Preparing the Server for Component Replacement
Servicing CRUs That Do Not Require Server Power-Off
Servicing Storage Drives and Rear Drives (CRU)
Servicing Fan Modules (CRU)
Servicing Power Supplies (CRU)
Servicing CRUs That Require Server Power-Off
Servicing the DIMMs (CRU)
DIMM and Processor Physical Layout
DIMM Population Example for Optimal System Performance
DIMM Population Rules
DIMM Rank Classification Labels
Inconsistencies Between DIMM Fault LEDs and the BIOS Isolation of Faulty DIMMs
Using the Fault Remind Button
Remove Faulty DIMMs
Install DDR3 DIMMs
Servicing PCIe Cards (CRU)
PCIe Slot Locations
Remove a PCIe Card
Install a PCIe Card
Servicing the SAS Expander Module (CRU)
Remove the SAS Expander Module
Install the SAS Expander Module
Servicing the Air Baffle (CRU)
Remove the Air Baffle
Install the Air Baffle
Servicing the DVD Drive (CRU)
Remove the DVD Drive
Install the DVD Drive
Servicing the Internal USB Flash Drives (CRU)
Servicing the Oracle System Assistant USB Flash Drive
Remove an Internal USB Flash Drive
Install an Internal USB Flash Drive
Servicing the Battery (CRU)
Remove the Battery
Install the Battery
Servicing FRUs
Servicing Processors (FRU)
Servicing the Front and Rear Storage Drive Backplanes (FRU)
Servicing the Front LED/USB Indicator Modules (FRU)
Servicing Cables (FRU)
Servicing the Motherboard Assembly (FRU)
Server Filler Panel Requirements
Remove and Install Filler Panels
Install the Server Top Cover
Install the Fan Assembly Door
Remove Antistatic Measures
Reinstall the Server Chassis in the Rack
Return the Server to the Normal Rack Position
Reconnect Power and Data Cables
Power On the Server
Identifying the Server Ports
Gigabit-Ethernet Ports
Network Management Port
Serial Management Port
Video Connector
USB Ports
Setting Up BIOS Configuration Parameters
Managing the BIOS Configuration
Accessing the BIOS Setup Utility
Using Legacy or UEFI BIOS
Using BIOS for Resource Allocation
Common BIOS Setup Utility Tasks
BIOS Setup Utility Menu Options
BIOS Main Menu Selections
BIOS Advanced Menu Selections
BIOS IO Menu Selections
BIOS Boot Menu Selections
UEFI Driver Control Menu Selections
BIOS Save & Exit Menu Selections
Monitoring Components and Identifying SNMP Messages
Monitoring Component Health and Faults Using Oracle ILOM
Monitoring System Components
Identifying SNMP Trap Messages
Generic Host Events
Environmental Events
Hard Disk Drive Events
Power Events
Fan Events
Memory Events
Entity Presence Events
Physical Presence Events
Index
  1. Prepare the server for service.
    1. Power off the server and disconnect the power cords from the server power supplies.
      See Powering Down the Server.
    2. Extend the server into the maintenance position.
      See Extend the Server to the Maintenance Position.
    3. Attach an antistatic wrist strap.
      See Electrostatic Discharge Safety.
    4. Remove the server top cover.
      See Remove the Server Top Cover.
  2. Remove the air baffle by lifting the baffle up and out of the server.
    Figure 66 Removing the Air Baffle
    image:Figure showing how to remove the air baffle.
  3. Set the air baffle aside.
  4. Consider your next step:
    • If you removed the air baffle as part of another procedure, return to that procedure.
    • Otherwise, continue to Install the Air Baffle.
Related Information
