Network Connectivity Deployment Options
The connectivity options in Oracle ILOM arrive preconfigured
so Oracle ILOM can learn the physical server SP or CMM network address.
To better understand which connectivity properties are shipped enabled,
and which connectivity properties are required for your network
environment, see the following table.
Table 35 Connectivity Deployment Options and Default Settings
Network |
IPv 4, DHCP enabled
IP 6, Stateless, enabled
Management Port: MGMT |
Oracle ILOM, by default,
arrives configured to operate in a dual-stack IPv4 and IPv6 network
environment. Upon setting a physical network management connection
to the server or CMM, Oracle ILOM will attempt to learn the physical
address for the SP or CMM from the IP mapping and routing devices
configured on the network.
Network administrators can accept the default dual-stack IP network
properties in Oracle ILOM, or choose to disable them and configure
the required IP network properties.
Related Information:
DNS |
The Auto DNS property in
Oracle ILOM uses DHCP to automatically assign the DNS named server
and search path.
Network administrators can accept the default Auto DNS properties
in Oracle ILOM or choose to disable them and configure the required
DNS name server and search path.
Serial Ports |
Owner=
SP
Baud Rate: = 9600
Flow Control = none
The console output functionality for
the physical serial management port on the server is controlled
by the server SP.
Network administrators can accept the server SP as the default serial port owner, or switch
the port ownership to the host server operating system.
On most servers, the default baud rate is set, by default, to 9600.
