Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 3.2.x
Exit Print View
Updated: November 2019
Default Timeout for CLI and Web Sessions
Oracle ILOM provides configurable properties that control the amount of minutes a web or command-line client can be inactive before Oracle ILOM terminates the session.
The default timeout session for authorized web users is set to 15 minutes, and the default timeout session set for authorized command-line users is 0 minutes (which means no set CLI default timeout). To prevent unauthorized use of an unattended session, you should configure a suitable timeout for all web and CLI users.
For CLI session timeout configuration properties, see Figure 43, Table 43, CLI Session Timeout and Custom Prompt Configuration Properties. For web session timeout configuration properties, see Figure 38, Table 38, Web Server Configuration Properties.
