Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) Documentation Collection for Firmware Release 3.2.x
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM Firmware Version Numbering Scheme
Access to Oracle Support
Getting Started
Oracle ILOM – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Supported Web Browsers for Oracle ILOM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
Oracle ILOM Remote KVMS Consoles Supported
Establishing a Host Serial Console Session to the Server
Redirecting an Image File From a Remote Device to the Host Server
Using the Oracle ILOM Remote System Console or Storage Redirection CLI
Remote System Console First-Time Setup
Launching and Using the Oracle ILOM Remote System Console
Remote System Console Menu Options, Usage Considerations, and Toggle Keys
Oracle ILOM Storage Redirection CLI
Storage Redirection CLI First-Time Setup
Launching and Using the Oracle ILOM Storage Redirection CLI
Using the Oracle ILOM Remote System Console Plus
Remote System Console Plus First-Time Setup
Launching and Using the Oracle ILOM Remote System Console Plus
Remote System Console Plus Menu Options, Usage Considerations, and Supported Keyboards
Toggle Button, Virtual Keys, and Status Icons
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Configuring SPARC Verified Boot Properties
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting SPARC Host State Capture
Managing SPARC Host I/O Reconfiguration Policy
Redirecting Host Output to Rear VGA Port
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Managing ASR Component States
Managing Active and Standby SP Redundancy Roles (SPARC)
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.2.x
Navigating the Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Oracle Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Managing Oracle Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Oracle Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Oracle ILOM Quick Reference for CLI Commands
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP and IPMI Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
Oracle ILOM SNMP MIBs
SNMP Command-Line Syntax Examples
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Budget (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Updates to Oracle ILOM 3.2.1 Firmware
Initial 3.2.1 Point Releases for Servers and Sun Blade 6000 Chassis
New 3.2.1 Features and Enhancements Summary
Oracle ILOM 3.2.1 Known Issues
Documentation Updates and Known Issues
Updates to Oracle ILOM 3.2.2 Firmware
New Features and Enhancements for Oracle ILOM 3.2.2
Known Issues as of Oracle ILOM 3.2.2
Resolved Issues as of Oracle ILOM 3.2.2
Glossary
Index
On some of Oracle's SPARC systems, Verified Boot can be used to verify system boot blocks and Oracle Solaris kernel modules before they are loaded on the system. Use Oracle ILOM to enable Verified Boot and to specify how the system should respond when a verification check fails. Enabling Verified Boot can prevent harmful changes to the system boot blocks or Oracle Solaris kernel modules from taking effect. For further details about setting this policy in Oracle ILOM, see the following table.
To use the Verified Boot feature, Oracle Solaris 11.2 or later must be installed on the system.
Before you upload certificates to verify Oracle Solaries kernel modules, ensure that the following requirements are met:
Table 67 Verified Boot Properties
User Interface Configurable Target and User Role:
  • SP CLI: /HOST/verified_boot
  • Domain CLI: /HOSTx/verified_boot, where x is the number of the host domain on a multi-domain system
  • Web: Host Management > Verified Boot
  • User Role: Reset and Host Control (r) role
Property
Default
Description
Boot Policy
(boot_policy )
none
none |warning|enforce
  • none – The system does not run verification checks on boot blocks, unix, or geunix.
  • warning – When a verification check fails, a warning message is logged on the host console, and the boot process continues.
  • When a verification check fails, an error message is logged on the host console, and the boot process is aborted.
CLI Syntax for Boot Policy:
set /HOST|HOSTx/verified_boot boot_policy=none|warning|enforce
Module Policy (module_policy)
none
  • none – The system does not run verification checks on Oracle Solaris kernel modules.
  • warning – When a verification check fails, a warning message is logged on the host console, and the kernel module is loaded.
  • When a verification check fails, an error message is logged on the host console, and the kernel module is not loaded.
CLI Syntax for Module Policy:
set /HOST|HOSTx/verified_boot module_policy=none|warning|enforce
System Certificates
(/system_certs/1)
View the system_certs/1 target for details about pre-installed certificate files, such as the issuer and subject of the file.
User Certificates
(/user_certs/n)
Load up to five custom certificate files to verify Solaris kernel modules other than unix and geunix. View the user_certs/n target for details about user-loaded certificate files, such as the issuer and subject of the files.
CLI Syntax for Loading a Custom Certificate File at Boot:
set /HOST|HOSTx/verified_boot/user_certs/n load_uri=protocol://certificate_URI, where n is the ID you want to associate with the certificate file and protocol is any of the transfer protocols supported by Oracle ILOM. For a list of supported protocols, see Supported File Transfer Methods.
CLI Syntax for Removing a Custom Certificate File for Verified Boot:
reset /HOST|HOSTx/verfied_boot/user_certs/n, where n is the ID of the certificate file you want to remove.
