Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Concepts Guide     Oracle Solaris Cluster 3.3 3/13
search filter icon
search icon
Document Information
Preface
1.  Introduction and Overview
2.  Key Concepts for Hardware Service Providers
3.  Key Concepts for System Administrators and Application Developers
Index
Preface
The Oracle Solaris Cluster Concepts Guide contains conceptual information about the Oracle Solaris Cluster product on both SPARC and x86 based systems.
Note - This Oracle Solaris Cluster release supports systems that use the SPARC and x86 families of processor architectures: UltraSPARC, SPARC64, AMD64, and Intel 64. In this document, x86 refers to the larger family of 64-bit x86 compatible products. Information in this document pertains to all platforms unless otherwise specified.
Who Should Use This Book
This document is intended for the following audiences:
To understand the concepts that are described in this book, you should be familiar with the Oracle Solaris operating system and have expertise with the volume manager software that you can use with the Oracle Solaris Cluster product.
You should determine your system requirements and purchase the required equipment and software. The Oracle Solaris Cluster Data Services Planning and Administration Guide contains information about how to plan, install, set up, and use the Oracle Solaris Cluster software.
How This Book Is Organized
The Oracle Solaris Cluster Concepts Guide contains the following chapters:
Chapter 1, Introduction and Overview provides an overview of the overall concepts that you need to know about Oracle Solaris Cluster.
Chapter 2, Key Concepts for Hardware Service Providers describes the concepts that hardware service providers should understand. These concepts can help service providers understand the relationships between hardware components. These concepts can also help service providers and cluster administrators better understand how to install, configure, and administer cluster software and hardware.
Chapter 3, Key Concepts for System Administrators and Application Developers describes the concepts system administrators and developers who will use the Oracle Solaris Cluster application programming interface (API) should know. Developers can use this API to turn a standard user application, such as a web browser or database, into a highly available data service that can run in the Oracle Solaris Cluster environment.
Related Documentation
Information about related Oracle Solaris Cluster topics is available in the documentation that is listed in the following table. All Oracle Solaris Cluster documentation is available at http://www.oracle.com/technetwork/indexes/documentation/index.html#sys_sw.
Topic
Documentation
Concepts
Hardware installation and administration
Oracle Solaris Cluster 3.3 3/13 Hardware Administration Manual and individual hardware administration guides
Software installation
Data service installation and administration
Data service development
System administration
Software upgrade
Error messages
Command and function references
Getting Help
If you have problems installing or using the Oracle Solaris Cluster software, contact your service provider and provide the following information:
Use the commands in the following table to gather information about your systems for your service provider.
Command
Function
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
showrev -p
Reports which patches are installed
SPARC: prtdiag -v
Displays system diagnostic information
/usr/cluster/bin/clnode show-rev -v
Displays Oracle Solaris Cluster release and package version information
You should also have available the contents of the /var/adm/messages file.
Access to Oracle Support
Oracle customers have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P-1 Typographic Conventions
Typeface
Description
Example
AaBbCc123
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
What you type, contrasted with onscreen computer output
machine_name% su
Password:
aabbcc123
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
AaBbCc123
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows UNIX system prompts and superuser prompts for shells that are included in the Oracle Solaris OS. In command examples, the shell prompt indicates whether the command should be executed by a regular user or a user with privileges.
Table P-2 Shell Prompts
Shell
Prompt
Bash shell, Korn shell, and Bourne shell
Bash shell, Korn shell, and Bourne shell for superuser
C shell
machine_name%
C shell for superuser
machine_name#
