Skip Navigation Links
Exit Print View
Oracle Solaris Cluster 3.3 3/13 Release Notes     Oracle Solaris Cluster 3.3 3/13
search filter icon
search icon
Document Information
Preface
What's New in the Oracle Solaris Cluster 3.3 3/13 Software
Support for Oracle 12c
Qualification of VxVM and VxFS
New clsetup Wizards to Create a Zone Cluster
Resource Dependencies Can Be Defined on a Per-Node Basis
Support for Kernel Cage Dynamic Reconfiguration (DR)
Cluster Security Framework Is Enhanced
Faster Failure Detection and Response by Storage Monitors
New clsetup Wizard to Configure the Oracle PeopleSoft Application Server Data Service
New clsetup Wizard to Configure the Oracle WebLogic Server Data Service
New Data Service for Oracle External Proxy
New Data Service for SAP NetWeaver
New Data Service for Oracle PeopleSoft Enterprise Process Scheduler
New Data Service for Oracle Web Tier
Support for Sun ZFS Storage Appliance Data Replication With Geographic Edition
Restrictions
Oracle ACFS as a Cluster File System
Topology Pages in Oracle Solaris Cluster Manager
Commands Modified in This Release
Compatibility Issues
Oracle ASM With Solaris Volume Manager Mirrored Logical Volumes
ACFS Proxy Resource Goes Offline During Installation of Oracle Binaries (16581850)
Tavor InfiniBand (IB) Transport Cluster Nodes Panic: mutex_enter: bad mutex, lp (16372022)
Solaris Upgrade to Oracle Solaris 10 8/11 Overwrites the hostname.adp Contents (15882549)
Solaris Volume Manager GUI
Accessibility Information
Supported Products
Data Services
File Systems
Memory Requirements
Oracle Solaris Operating System
Oracle VM Server for SPARC
Availability Suite
Volume Managers
Features Not Supported in This Release
Sun Management Center
Network Appliance NAS Devices
Socket Direct Protocol (SDP)
Product Localization
Known Issues and Bugs
Administration
Cannot Set the Jumbo Frame MTU Size for the clprivnet Interface (16618736)
Cluster Check Utility S6708502 Reports RT Process ora_dism as Unsupported (16365116)
Public Net Failure Does Not Fail Over DB Server Resource with SCAN Listener (16231523)
Cluster File System Does Not Support Extended Attributes (15790565)
Resource Group Does Not Fail Over When Failover_mode Is Set to SOFT During a Public Interface Failure (15711034)
Unable to Register Resource Type SUNW.scalable_acfs_proxy in a Zone Cluster (15700050)
The clzonecluster boot, reboot, and halt Subcommands Fail if Any One of the Cluster Nodes Is Not in the Cluster (15812235)
Using chmod to Set setuid Permission Returns Error in a Non-Global Zone on PxFS Secondary Server (15697690)
Cannot Create a Resource From a Configuration File With Non-Tunable Extension Properties (15658184)
Disabling Device Fencing While Cluster Is Under Load Results in Reservation Conflict (15608862)
Autodiscovery Does Not Work on LDoms With Hybrid I/O (15581535)
EMC SRDF and Hitachi TrueCopy Should Reject Switchover When Replicated Device-Group Status Will Cause Switchover and Switchback to Fail (15538295)
Removing Nodes from the Cluster Configuration Can Result in Node Panics (15500647)
More Validation Checks Needed When Combining DIDs (15423531)
Data Services
sun.storage_proxy.type Resource in Offline State After uadmin 5 1 (16910145)
Active-Standby Configuration Not Supported for HA for TimesTen (16861602)
The clzonecluster halt zonecluster Command Followed by clzonecluster boot zonecluster Causes Node Boot Failure in a Zone Cluster (16398199)
Disabled LDom Resource Keeps the LDom in a Bound State (16323723)
Manual Umount of ZFS File System Does Not Get Remounted Automatically (16319552)
Oracle HTTP Server (OHS) Agent Calls /bin/grep -q, Which Is an Illegal Option for This grep Version (16270576)
Errors Occur When Deleting an HA LDom Resource (16229698)
The clsetup WebLogic Server Wizard Does Not Create a Resource for a Failover File System in a Zone Cluster Zone (15943191)
Wizard Unable to Create Zone Cluster rac-framework Resource Group if the Zone Cluster Has Fewer Nodes Than Its Global Zone Nodes (15825830)
Oracle Solaris 10 Samba Patch 119757-20 or 119758-20 Impacts the HA-Samba Data Service (15757158)
When set Debug_level=1, pas-rg Fails Over to Node 2 And Cannot Start on Node 1 Anymore (15803844)
HAStoragePlus Resource Configured in Scalable Resource Group with Cluster File System Stays at Starting State Indefinitely (15649193)
Scalable Applications Are Not Isolated Between Zone Clusters (15611122)
Running clnas add or clnas remove Commands on Multiple Nodes at the Same Time Can Cause a Problem (15533979)
The clresourcegroup add-node Command Triggers an HAStoragePlus Resource to a Faulted State (15391480)
RAC Wizard Failing With "ERROR: Oracle ASM is either not installed or the installation is invalid!" (15814020)
Geographic Edition
Geographic Edition Hitachi TrueCopy Protection Group Takeover Fails When the Primary Cluster Loses Access to Storage (16013386)
Geographic Edition Disables ASM Resources in Incorrect Order, Resulting in Error Messages (16004984)
Cluster Node Does Not Have Access to ZFS Storage Appliance Projects or iSCSI LUNs (15924240)
Multiple Notification Emails Sent from Global Cluster When Zone Clusters Are in Use (15746425)
DR State Stays Reporting unknown on One Partner (15808054)
ZFS Storage Appliance Protection Group Creation And Validation Fail if Project Replication Is Stopped by Using the BUI (15797609)
Installation
Centralized Install with the scinstall Utility Fails to Configure the Cluster When DES Authentication is Enabled and the Node Names Are Specified as Fully Qualified Host Names (16228318)
The Zone Cluster Wizard Does Not Provide a Method to Enter Data on Nodes Using Oracle Solaris 10 OS (15874818)
Running the scinstall -u Command Leaves 'installed' Zones in 'mounted' State (15817301)
The Installer Deletes the Existing Package Corresponding to Ops Center Agent JavaDB Database (15646335)
Localization
Result of System Requirements Checking Is Wrong (12185261)
Runtime
The clzonecluster cancel Command Can Cause an Error (15950187)
sc_delegated_restarter Does Not Take Into Account Environment Variable Set in Manifest (15795184)
Unable to Re-enable Transport Interface After Disabling With ifconfig unplumb interface (15770198)
Failure of Logical Hostname to Fail Over Caused by getnetmaskbyaddr() (15733435)
Patches and Required Firmware Levels
Applying an Oracle Solaris Cluster 3.3 3/13 Core Patch
How to Apply the Oracle Solaris Cluster 3.3 3/13 Core Patch
Removing an Oracle Solaris Cluster 3.3 3/13 Core Patch
How to Remove an Oracle Solaris Cluster 3.3 3/13 Core Patch
Patch Management Tools
Patch for Cluster Support for Sun StorageTek 2530 Array
My Oracle Support
Oracle Solaris Cluster 3.3 3/13 Documentation Set
Documentation Addendum
Software Installation Guide
HA for Oracle Guide
HA for Oracle RAC Guide
HA for Oracle Web Tier Guide
Man Pages
Multiple Man Pages
Supported Products
This section describes the supported software and memory requirements for Oracle Solaris Cluster 3.3 3/13 software as of the time of publication. Contact your Oracle support representative to learn whether additional product versions become supported.
Data Services
Contact your Oracle sales representative for the complete list of supported data services (agents) and application versions.
File Systems
The following table describes the supported file systems for Oracle Solaris 10 on the SPARC and x86 platforms as of the time of publication.
File System
Additional Information
Failover UFS local file system
ZFS (exported as a data set)
Not supported for the /globaldevices file system
QFS standalone file system and QFS shared file system (only when used to support Oracle Real Application Clusters)
NFS from supported NAS devices
VxFS
Requires a minimum of Oracle Solaris 10 1/13 software
Memory Requirements
Oracle Solaris Cluster 3.3 3/13 software requires the following memory requirements for every cluster node:
Actual physical memory and hard drive requirements are determined by the applications that are installed. Consult the application's documentation or contact the application vendor to calculate additional memory and hard drive requirements.
Oracle Solaris Cluster 3.3 3/13 software and Quorum Server software requires one of the following versions of the Oracle Solaris OS as of the time of publication:
Note - Oracle Solaris Cluster 3.3 3/13 software does not support multiple versions of Oracle Solaris software in the same running cluster.
This Oracle Solaris Cluster release supports Oracle VM Server for SPARC 2.2 and 3.0 as of the time of publication.
Availability Suite
This Oracle Solaris Cluster release supports Availability Suite 4.0 software as of the time of publication. Support requires a minimum of patch 123246-07 for SPARC or 123247-07 for x86.
Volume Managers
The following volume managers are supported for Oracle Solaris 10 on the SPARC and x86 platforms as of the time of publication:
