Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
QoS Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Configuration Overview
QoS Management Architecture
Configuring QoS
Introduction
Classifying and Conditioning Ingress Traffic
Introduction
Define an ACL and Access Group
Define TCP and UDP Traffic
Define VLAN Tagged Packets
Define Incoming Packet Priorities
Define the Traffic Classes With the class-map Command
Set the Rate and Burst Tolerance of a Traffic Stream
Set up the Ingress Policy
Classifying and Scheduling Egress Class Traffic
Define the Egress Scheduler Behavior
Define a General Shaper
Insatiate Egress Queues
Mapping Ingress Traffic to Egress Class
Map Ingress Traffic to Egress Class
You can define a class of VLAN tagged packets and apply them to an interface.
  1. Use the mac access-list command to define the VLAN packages.
    SEFOS# configure terminal
    SEFOS(config)# mac access-list extended 50
    SEFOS(config-ext-macl)# permit any any Vlan 1000
    SEFOS(config-ext-macl)# exit
    SEFOS(config)# mac access-list extended 55
  2. Apply the tagged packets to interface 0/3.
    SEFOS(config)# interface extreme-ethernet 0/3
    SEFOS(config-if)# mac access-group 50 in
    SEFOS(config-if)# mac access-group 55 in
    SEFOS(config-if)# end
  3. Review the access list for mac 50.
    SEFOS# show access-lists mac 50
    Extended MAC Access List 50
    Filter Priority            : 1
    Ether Type                 : 0
    Protocol Type              : 0
    Vlan Id                    : 1000
    User-Priority              : 0
    Destination MAC Address    : 00:00:00:00:00:00
    Source MAC Address         : 00:00:00:00:00:00
    In Port List               : Ex0/3
    Filter Action              : Permit
    Status                     : Active
  4. Review the access list for mac 55.
    SEFOS# show access-lists mac 55
    Extended MAC Access List 55
    Filter Priority            : 1
    Ether Type                 : 0
    Protocol Type              : 0
    Vlan Id                    : 0
    User-Priority              : 0
    Status                     : Active
