Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
VLAN Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
VLAN Configuration
Configuration Guidelines
Default Settings
Configuring Static VLAN Entries
Create Member Ports
Create Forbidden Ports
Viewing VLAN Information
Retrieve the VLAN Summary
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Delete a VLAN
Enable VLANs
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring QinQ
Enable Tunneling on a Port
Enable STP Packet Tunneling
Configure QinQ
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configuring Port Filtering
Configure the Acceptable Frame Type
Configure Ingress Filtering
Flow-Based Configuration
Flow-Based Example Topologies
Example Topolgy 1
Example Topolgy 2
Example Topolgy 3
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configuring GVRP
Configure VGRP for Topology 1
Configure VGRP for Topology 2
Configure VLANs on the Nonroot Bridge
Configure GMRP
Classify VLANs
Create Acceptable Frame Types
To work with acceptable frame types, you must ensure that the follow prerequisites are met:
See Default Settings for the topology for this procedure.
  1. Configure the VLAN in switch 1.
    SEFOS# configure terminal
    SEFOS(config)# vlan 15
    SEFOS(config-vlan)# ports extreme-ethernet 0/15,0/19 untagged extreme-ethernet 0/15,0/19
    SEFOS(config-vlan)# exit
    SEFOS(config)# interface extreme-ethernet 0/15
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# switchport pvid 5
    SEFOS(config-if)# exit
    SEFOS(config)# interface extreme-ethernet 0/19
    SEFOS(config-if)# end
  2. Wait for at least 30 seconds for the topology to settle, then ping host B from host A.
    The ping must be successful.
  3. On switch 1, configure the acceptable frame type for port P15.
    SEFOS(config-if)# switchport acceptable-frame-type tagged
    SEFOS(config-vlan)# end
  4. Review the VLAN-related configurations.
    SEFOS# show vlan id 5
    Vlan database
    Vlan ID             : 5
    Member Ports        : Ex0/15, Ex0/19
    Untagged Ports      : Ex0/15, Ex0/19
    Forbidden Ports     : None
    Name                :
    Status              : Permanent
  5. Review the VLAN port configuration table.
    SEFOS# show vlan port config port extreme-ethernet 0/15
    Vlan Port configuration table
    Port Ex0/15
    Port Vlan ID                       : 5
    Port Acceptable Frame Type         : Admit Only Vlan Tagged
    Port Ingress Filtering             : Disabled
    Port Mode                          : Hybrid
    Port Gvrp Status                   : Enabled
    Port Gmrp Status                   : Enabled
    Port Gvrp Failed Registrations     : 0
    Gvrp last pdu origin               : 00:00:00:00:00:00
    Port Restricted Vlan Registration  : Disabled
    Port Restricted Group Registration : Disabled
    Mac Based Support                  : Disabled
    Subnet Based Support               : Disabled
    Port-and-Protocol Based Support    : Enabled
    Default Priority                   : 0
    Tunnel Status                      : Disabled
    Dot1x Protocol Tunnel Status       : Peer
    LACP Protocol Tunnel Status        : Peer
    Spanning Tree Tunnel Status        : Peer
    GVRP Protocol Tunnel Status        : Peer
    GMRP Protocol Tunnel Status        : Peer
    IGMP Protocol Tunnel Status        : Peer
    Filtering Utility Criteria         : Default
    Port Protected Status              : Disabled
    After you configure the acceptable frame type as Admit OnlyVLAN Tagged, the ping from host A to host B should fail because ping(1M) packets are untagged.
