Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RIP Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RIP Overview
Protocol Description
Configuring the RIP Topology Example
RIP Topology 1
RIP Topology 2
Configure Switch 1
Configure Switch 2
Configure Switch 3
General Configurations
Managing RIP
Enable RIP
Disable RIP
Enabling RIP on an IP Network
Configuring RIP Security
Enable RIP Security
Disable RIP Security
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring RIP Neighbors
Add a RIP Neighbor
Remove a RIP Neighbor
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Output Delay
Enable the Output Delay
Disable the Output Delay
Configuring Redistribution
Enable Redistribution
Test Redistribution
Disable Redistribution
Configuring the Default Metric
Set the Default Metric
Test the Default Metric
Reset the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Configure Basic Timers
Configuring the split-horizon Option
Configuring the Debug Level for RIP
Enable Debug
Disable Debug
Product Notes
For late-breaking information and known issues about the following products, refer to the product notes at:
Oracle Switch ES1-24:
http://www.oracle.com/goto/ES1-24/docs
Sun Network 10GbE Switch 72p:
http://www.oracle.com/goto/SN-10GbE-72p/docs
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
http://www.oracle.com/goto/SB6K-24p-10GbE/docs
