Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
OSPF Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
OSPF Overview
Protocol Description
Topology Example
Configuring OSPF
Configuration Guidelines
Configuring VLAN Interfaces
Configure VLAN Interfaces Associated With SEFOS1
Configure VLAN Interfaces Associated With SEFOS2
Configure VLAN Interfaces Associated With SEFOS3
Configure VLAN Interfaces Associated With SEFOS4
Configure VLAN Interfaces Associated With SEFOS5
Configure VLAN Interfaces Associated With SEFOS6
Configure VLAN Interfaces Associated With SEFOS7
Configure VLAN Interfaces Associated With SEFOS8
Configure VLAN Interfaces Associated With SEFOS9
Enable OSPF
Disable OSPF
Configuring the Router ID and OSPF Interface
Configure the Router ID
Configure the OSPF Interface
Configuring the OSPF Interface Parameters
Enable OSPF Over the VLAN Interface
Configure the OSPF Interface Priority
Restore the Default Value of the OSPF Interface
Configure the LSA Retransmission Interval
Restore the Default Value of the Retransmission Interval
Configure the Link State Update Packet Transmission Delay
Restore the Default Value of the OSPF Transmission Delay
Configure the Interval Between Hello Packets
Restore the Default Value for the Interval Between Hello Packets
Configure the Interval That Declares a Router Is Down
Restore the Default Value for Declaring a Router Is Down
Configure the Network Type
Restore the Default Value for the OSPF Network Type
Configure the Demand Circuit
Remove the Demand Circuit Designation From the Interface
Configure the Interface Cost
Restore the Default Value for Interface Cost
Configuring the OSPF Testing Authentication Topology Example
Configure Simple Password Authentication
Configure the Message-Digest Authentication
Configure the Null Authentication
Configuring the Passive Interface
Suppress Routing Updates on All the Interfaces
Restore Routing Updates on All Interfaces
Suppress Routing Updates on a Specified Interface
Restore Routing Updates on Interface VLAN 1
Configuring OSPF Area Parameters
Configuring the Stub Area, ASBR, and Route Redistribution
Stub Area, ASBR, and Route Redistribution Topology Example
Configure the Stub Area
Configure the ASBR Router
Disable the ASBR Router
Configure Redistribution
Disable Redistribution of Routes
Configure SEFOS4
Configure SEFOS5
Configure SEFOS7
Examine the Configuration Details in SEFOS4
Examine the Redistributed External Routes in SEFOS5
Examine the External Routes Not Distributed in Stub Area 0.0.0.4 in SEFOS7
Configuring the NSSA Area, Summary Address, and Area Default Cost
NSSA Configuration, Summary Address Configuration, and Area Default-Cost
Configure the NSSA Area
Reconfigure Area 0.0.0.6 as a Normal Area
Configure the Summary Address
Delete the Summary Address Configuration for 90.0.0.0/8 in the NSSA Area
Configure the Area Default Cost
Configure Default-Cost for the Default Summary Route Sent Into the NSSA Area
Configure SEFOS2
Configure SEFOS4
Configure SEFOS9
Examine the Configuration Details in SEFOS2
Examine the Configuration Details in SEFOS9
Test SEFOS9
Test SEFOS2
Test SEFOS9
Configure the P-bit Setting in the Default Type 7 LSA
Disable the P-bit Setting in the Default Type 7 LSA
Configure the NSSA Area Translation Role
Configure the Stability Interval for NSSA
Configure the ABR Type
Configure RFC 1583 Compatibility
Disable RFC 1583 Compatibility
Configuring the Generation of a Default External Route and Redistribution Configuration
Generation of a Default External Route and Redistribution Configuration Topology Example
Configure the Generation of a Default External Route
Disable Generation of a Default External Route
Configure the Redistribution Configuration
Delete the Information Applied to the Routes Learned From RTM
Configure SEFOS1
Configure SEFOS2
Configure SEFOS1
Test SEFOS1
Configure the Neighbor
Delete the Configured Neighbor
Configuring Virtual Links and Route Configuration
Virtual Link and Route Summarization Topology Example
Configure the Virtual Link
Delete the Virtual Link
Configure the Area Range
Delete the Route Summarization Information
Configure SEFOS1
Configure SEFOS4
Configure SEFOS5
Configure SEFOS6
Configure SEFOS8
Examine the Route Information and Virtual Links in SEFOS1
Examine the Virtual Link in SEFOS5
Examine the Virtual Link in SEFOS6
Examine the Route Available to Reach ABR SEFOS1
  1. Configure simple password authentication in SEFOS2.
    1. Type.
      SEFOS# configure terminal
      SEFOS(config)# router ospf
      SEFOS(config-router)# router-id 10.4.0.2
    2. Enable OSPF over the VLAN interface and associate the interface with an OSPF area.
      SEFOS(config-router)# network 10.4.0.2 area 0.0.0.0
    3. Exit Router Configuration mode.
      SEFOS(config-router)# exit
    4. Enter Interface Configuration mode.
      SEFOS(config)# interface vlan 1
    5. Configure the authentication key for simple password authentication.
      SEFOS(config-if)# ip ospf authentication-key 1234
    6. Enable simple password authentication.
    7. Exit Interface Configuration mode.
      SEFOS(config-if)# exit
    8. Exit Configuration mode.
      SEFOS(config)# exit
  2. Configure simple password authentication in SEFOS4.
    1. Type.
      SEFOS(config-router)# router-id 10.4.0.4
      SEFOS(config-router)# network 10.4.0.4 area 0.0.0.0
      SEFOS(config)# exit
  3. Examine the authentication type configured.
    SEFOS# show ip ospf interface
    vlan1 is line protocol is up
    Internet Address 10.4.0.2, Mask 255.255.0.0, Area 0.0.0.0
    AS 1, Router ID 10.4.0.2, Network Type BROADCAST, Cost 1
    Transmit Delay is 1 sec, State 5, Priority 1
    Designated RouterId 10.4.0.4, Interface address 10.4.0.4
    Backup Designated RouterId 10.4.0.2, Interface address 10.4.0.2
    Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    Hello due in 0 sec
    Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with the neighbor 10.4.0.4
    Simple password authentication enabled
  4. Examine the adjacency formed between the neighbors in SEFOS 2 and SEFOS 4.
    SEFOS# show ip ospf neighbor detail
    Neighbor 10.4.0.4, interface address 10.4.0.4
    In the area 0.0.0.0 via interface vlan1
    Neighbor priority is 1,  State is FULL/BACKUP, 5 state changes
    DR is 10.4.0.4 BDR is 10.4.0.2
    Options is 0x2
  5. Remove a previously assigned OSPF password.
    SEFOS(config-if)# no ip ospf authentication-key
