Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
Whenever you create a port channel, the channel is added as an untagged member port of the default VLAN 1. For other VLANs, you must explicitly configure the channel as a member port, or the channel must be dynamically learned through GVRP. The channel does not inherit the VLAN membership of its member ports. When a port is aggregated into a bundle, that port will not be visible to layer 2 applications like VLAN and STP. Only the port of the port channel is visible to layer 2 applications. When a port gets aggregated into a port channel port, the port is removed from the membership of the specific VLAN. Similarly, when a port is deaggregated from a port channel, the port is added as a member port of the default VLAN.
To demonstrate this behavior, perform these steps.
  1. Review the VLANs that are configured in the switch.
    SEFOS# show vlan
    Vlan database
    Vlan ID             : 1
    Member Ports        : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6
                          Ex0/7, Ex0/8, Ex0/9, Ex0/10, Ex0/11, Ex0/12
                          Ex0/13, Ex0/14, Ex0/15, Ex0/16, Ex0/17, Ex0/18
                          Ex0/19, Ex0/20, Ex0/21, Ex0/22, Ex0/23, Ex0/24
    Untagged Ports      : Ex0/1, Ex0/2, Ex0/3, Ex0/4, Ex0/5, Ex0/6
    Forbidden Ports     : None
    Name                :
    Status              : Permanent
    Vlan ID             : 2
    Name                :
    Status              : Permanent
  2. Aggregate port 1 and port 2 into a bundle.
    SEFOS(config)# set port-channel enable
    SEFOS(config)# interface port-channel 1
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# exit
    SEFOS(config)# interface extreme-ethernet 0/1
    SEFOS(config-if)# channel-group 1 mode active
    SEFOS(config)# interface extreme-ethernet 0/2
  3. Review the VLAN configuration information.
    SEFOS# show vlan
    Vlan database
    Vlan ID             : 1
    Member Ports        : Ex0/3, Ex0/4, Ex0/5, Ex0/6, Ex0/7, Ex0/8
                          Ex0/9, Ex0/10, Ex0/11, Ex0/12, Ex0/13, Ex0/14
                          Ex0/15, Ex0/16, Ex0/17, Ex0/18, Ex0/19, Ex0/20
                          Ex0/21, Ex0/22, Ex0/23, Ex0/24, po1
    Untagged Ports      : Ex0/3, Ex0/4, Ex0/5, Ex0/6, Ex0/7, Ex0/8
    Name                :
    Status              : Permanent
    Vlan ID             : 2
    Name                :
    Status              : Permanent
    After you create a port channel, the member ports of bundle 1 and bundle 2 are removed from all of the VLANs. The port channel port becomes the member of the default VLAN.
  4. Delete the port channel, and review the VLAN configuration information.
    SEFOS(config)# no interface port-channel 1
    SEFOS(config)# exit
    SEFOS# show vlan
    Vlan database
    Vlan ID             : 2
    Name                :
    Status              : Permanent
    Vlan ID             : 1
    Name                :
    Status              : Permanent
    After you delete the port channel, note the port channel port is removed from the VLAN. Member ports of bundles 1 and bundle 2 become members of the default VLAN, but not of other VLANs.
