Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable a New IP Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a New VLAN Name
Enable an Existing VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
This section describes how to configure IEEE 802.3 organizationally-specific TLVs for transmission when the transmission status is set to disabled by default. The following basic optional TLVs are in LLDP:
  1. At both switches, configure the LLDP module status as enabled.
    See Configure the LLDP Module Status.
  2. Enable the IEEE 802.3 organizationally-specific TLVs on the extreme-ethernet 0/1 interface.
    SEFOS# configure terminal
    SEFOS(config)# interface extreme-ethernet 0/1
    SEFOS(config-if)# lldp tlv-select dot3tlv macphy-config link-aggregation max-framesize
    SEFOS(config)# end
  3. At switch 1, review the local system information.
    SEFOS# show lldp local extreme-ethernet 0/1
    Enabled Tx Tlvs            : Mac Phy, Link Aggregation, Max Frame Size
  4. At switch 2, review the information about the learned neighbors on the interface.
    SEFOS# show lldp neighbors extreme-ethernet 0/1 detail
    Extended 802.3 TLV Info
    -MAC PHY Configuration & Status
    Auto-Neg Support & Status        : Supported, Disabled
    Advertised Capability Bits        : 0000
    -Link Aggregation
    Capability & Status            : Not Capable, Not In Aggregation
    Aggregated Port Id            : 1
    -Maximum Frame Size            : 9216
