Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable a New IP Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a New VLAN Name
Enable an Existing VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
LLDP remote table is updated whenever LLDP operates in the transmit and receive-receive only modes.
  1. At both switches, configure the LLDP module status as enabled.
    See Configure the LLDP Module Status.
  2. On both switches, enter the Global Configuration mode.
    SEFOS# configure terminal
  3. Allow both switches to learn the neighbors, then clear the LLDP remote table.
    SEFOS(config)# clear lldp table
    SEFOS(config)# end
  4. On both switches, review the remote table.
    SEFOS# show lldp neighbors
    Capability Codes        :
    (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device,
    (W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
    Chassis ID        Local Intf        Hold-time    Capability    Port Id
    Total Entries Displayed    : 0
