Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable a New IP Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a New VLAN Name
Enable an Existing VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
This section contains instructions on how to configure the LLDP trace options. By default, only the critical trace setting is enabled.
  1. At switch 1, review the current setting for the default trace option.
    SEFOS# debug lldp
    LLDP critical debugging is on
  2. Enable all of the trace options.
    SEFOS# debug lldp all
  3. Review the setting for the trace option.
    SEFOS# debug lldp
    LLDP all debugging is on
  4. Disable all of the trace options.
    SEFOS# no debug lldp all
  5. Review the trace options.
    SEFOS# debug lldp
    No traces are displayed after you disable all of the traces.
  6. Enable packet dump, neighbor update, and VLAN name TLV traces.
    SEFOS# debug lldp pkt-dump neigh-updt tlv vlan-name
  7. Review the trace options.
    SEFOS# debug lldp
    LLDP packet dump debugging is on
    LLDP Neighbor Update debugging is on
    LLDP Vlan Name tlv debugging is on
  8. Disable the neighbor update trace.
    SEFOS# no debug lldp neigh-updt
  9. Review the trace options.
    SEFOS# debug lldp
    The neighbor update trace is not displayed.
