Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
DCB Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Purpose and Scope
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
DCB Protocol
Priority Group Feature
PFC Feature
Application Protocol Feature
Topology Setup
Configuring DCB
Configuration Specifications
Host Blade Configuration
Switch A
Switch B
Storage Array Server
Configuration Guidelines
Default Settings
Configure DCB Features
Verifying DCB and LLDP Configurations
Determine VLAN Assignment
Determine Whether Interfaces Are Active
Determine Whether LLDP is Running and Recognizing Peers
Enable DCB
Disable DCB
Enable DCB for Each Interface
Disable DCB for Each Interface
Enable and Disable a Specific DCB Feature
Configure the Mode for the DCB Feature
Configure DCB Attributes
Configure LLDP DCBX TLVs
Display DCBX Feature Statistics and Control Information
Display Output of Unstarted DCBX Protocol Exchange
Display Output of DCBX TLV Exchange
Display Output of No TLV Exchange
Clear Feature Statistics
Display Output Showing a Down Link
Product Notes
For late-breaking information and known issues about the following products, refer to the product notes at:
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
http://www.oracle.com/pls/topic/lookup?ctx=SB6K-24p-10GbE
Sun Network 10GbE Switch 72p:
http://www.oracle.com/pls/topic/lookup?ctx=SN-10GbE-72p
