Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IPv6 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Topologies
Basic SEFOS IPv6 Topology
Route Redistribution Topology in IPv6
General Configurations
Default Settings
Completing Preliminary Configurations
Create an Interface
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configure Switch 1
Configure Switch 2
Configuring the Route Redistribution Topology
Configure Switch 1
Configure Switch 2
Configure Switch 3
IPv6 Feature Configuration
Configuring IPv6 Support in an Interface
Enable IPv6 Support
Disable IPv6 Support
Configuring IPv6 Addressing
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Routing
Enable IPv6 Routing
Disable IPv6 Routing
Configuring IPv6 Static Routes
Add a Static Route
Remove a Static Route
Configuring Static Neighbor Cache Entries
Add a Neighbor Cache Entry
Delete a Neighbor Cache Entry
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Configuring DAD Entries
Set the DAD Attempts
Reset the DAD Attempts
Configuring PMTU Discovery
Enable PMTU Discovery
Disable PMTU Discovery
Setting the MTU for Use in PMTU Discovery
Set the MTU for Use in PMTU Discovery
Configuring the IPv6 Route Redistribution Policy for Routing Protocols
Configure the IPv6 Route Redistribution Policy for Routing Protocols
  1. Review the routing information in the routing table on switch 1.
    SEFOS# show ipv6 route
    VRF    Name:      default
    IPv6 Routing Table
    Codes : C - Connected, S - Static
            O - OSPF, R - RIP, B - BGP
    C   fec0::1111:0:0/96   [1/1]
            via ::, vlan1
    C   fec0::2222:0:0/96   [1/1
            via ::, vlan3
  2. Review the routing information in the routing table on switch 2.
    IPv6 Routing Table:
    C   fec0::2222:0:0/96   [1/1]
            via ::, vlan3
    C   fec0::3333:0:0/96   [1/1]
            via ::, vlan2
  3. Review the routing information in the routing table on switch 3.
    IPv6 Routing Table:
            via ::, vlan2
    C   fec0::4444:0:0/96   [1/1]
            via ::, vlan1
    All of the connected routes are listed in all of the routing tables.
  4. On switch 1, configure the redistribution policy for the destination IP so that the redistribution of that route to the destination protocol is permitted or not permitted by switch 2.
    SEFOS# configure terminal
    SEFOS(config)# redistribute-policy ipv6 deny fec0::4444:0:0 96 rip ospf
    Redistribution of each route is permitted by default in each router. If the redistribution of a particular route is to be denied, configure the redistribution policy for that route.
  5. On switch 1, enable the OSPF routing protocol for the VLAN 3 interface.
    SEFOS(config)# ipv6 router ospf
    SEFOS(config-router)# router-id 1.1.1.1
    SEFOS(config-router)# ASBR Router
    SEFOS(config-router)# redistribute connected
    SEFOS(config-router)# exit
    SEFOS(config)# interface vlan 3
    SEFOS(config-if)# ipv6 ospf area 0.0.0.0
    SEFOS(config-if)# end
  6. On switch 2, enable the OSPF routing protocol for the VLAN 3 interface.
    SEFOS(config-router)# router-id 2.2.2.2
    SEFOS(config-router)# redistribute ripng
    SEFOS(config-if)# exit
  7. On switch 2, enable the RIP routing protocol for the VLAN 2 interface.
    SEFOS(config)# ipv6 router rip
    SEFOS(config-router)# redistribute ospf
    SEFOS(config)# interface vlan 2
    SEFOS(config-if)# ipv6 rip enable
  8. On switch 3, enable the RIP routing protocol for the VLAN 2 interface.
  9. Review the routing information in the routing table for switch 1.
    IPv6 Routing Table:
            via ::, vlan1
            via ::, vlan3
    O   fec0::3333:0:0/96   [10/110]
            via fe80::203:2ff:fe03:201, vlan3
    The information about route fec0::3333:0:0 is not learned because the policy is set to deny. To permit the redistribution of this route, execute the following commands in switch 2:
    SEFOS(config)# no redistribute-policy ipv6 fec0::4444:0:0 96
    SEFOS(config)# redistribute-policy ipv6 permit fec0::4444:0:0 96 rip ospf
    SEFOS(config)# exit
    O   fec0::4444:0:0/96   [10/110]
  10. Review the routing information in the routing table on switch 2.
    IPv6 Routing Table:
    O   fec0::1111:0:0/96   [10/110]
            via fe80::201:2ff:fe03:401, vlan3
            via ::, vlan3
            via ::, vlan2
    R   fec0::4444:0:0/96   [2/120]
            via fe80::203:2ff:fe03:401, vlan2
  11. Review the routing information in the routing table on switch 3.
    The routes to all of the networks are learned using the routing protocols in each router after the route redistribution is configured.
    IPv6 Routing Table:
    R   fec0::1111:0:0/96   [2/120]
            via fe80::202:2ff:fe03:401, vlan2
    R   fec0::2222:0:0/96   [2/120]
            via ::, vlan2
            via ::, vlan1
