Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PVRST+ Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
PVRST+ Overview
Protocol Description
Topology Example
Default Settings
Rapid STP
Bridge ID and Switch Priority
Election of the Root Switch
Port States
Port Roles
Rapid Convergence
Proposal Agreement Sequence
Topology Change and Topology Change Detection
VLAN Module
Configuring RSTP in PVRST+
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Spanning-Tree Path Cost
Configure the Spanning Tree Link Type
Configure the Spanning-Tree portfast Setting
Configure Spanning Tree Timers
Display the Spanning Tree Status
Configure the Transmit Hold Count
Configure Encapsulation
Configure the BPDU Guard
Configure the Root Guard
Configuring the VLAN Module
Disable GVRP
Configuring Trunk and Access Ports
Configure a Trunk Port
Configure an Access Port
Set Up PVID on a Port
Configure VLANS and Display the PVRST+ Information for VLANs
PVRST+ is an enhancement of RSTP, which works in conjunction with VLANs to provide better control over traffic in the network. A separate spanning tree is maintained for each active VLAN in the network, providing load balancing through multiple instances of the spanning tree, the fault tolerance (because failure of one spanning tree instance does not affect other spanning trees), and rapid reconfiguration support through the RSTP.
Rapid spanning tree is a link management protocol that provides path redundancy, while preventing undesirable loops in the network, such as multiple active paths between stations. To establish path redundancy, STP creates a tree that spans all of the switches in an extended network, forcing redundant paths into a standby or blocked state.
For an Ethernet network to function properly, only one active path must exist between two stations. Multiple active paths between stations in a bridged network can cause loops in which Ethernet frames can endlessly circulate. STP can logically break such loops and prevent looping traffic from clogging the network. The dynamic control of the topology provides continued network operation in the presence of redundant or unintended looping paths.
