Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RMON Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RMON Overview
Protocol Description
Topology Example
Configuring RMON
Enabling the RMON Module
Enable the RMON Module
Disable the RMON Module
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
Disable the Ethernet History Group
Configuring Events
Create an Event
Disable an Event
Configuring Alarms
Create an Alarm
Disable an Alarm
Create an Event
  1. Enter Global Configuration mode.
    SEFOS# configure terminal
  2. Create an event that can be triggered for every rise in the flow of packets.
    SEFOS(config)# rmon event 1 description rise log owner myTest trap PUBLIC
  3. Create an event that can be triggered for every fall in the flow of packets.
    SEFOS(config)# rmon event 2 description fall log owner myTest trap NETMAN
    SEFOS(config)# exit
  4. Review the RMON events.
    SEFOS# show rmon events
    RMON is enabled
    Event 1 is active, owned by myTest
     Description is rise
     Event firing causes log and trap to community PUBLIC,
     Time last sent is Feb  9 15:01:37 2010
     Logging Event With Description : rise
    Event 2 is active, owned by system
     Description is fall
     Event firing causes log and trap to community NETMAN,
     Time last sent is Feb  9 14:59:07 2010
     Logging Event With Description : fall
