Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RMON Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RMON Overview
Protocol Description
Topology Example
Configuring RMON
Enabling the RMON Module
Enable the RMON Module
Disable the RMON Module
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
Disable the Ethernet History Group
Configuring Events
Create an Event
Disable an Event
Configuring Alarms
Create an Alarm
Disable an Alarm
Configuring Alarms
The alarm group periodically takes statistical samples from variables in the probe and compares them with the thresholds that have been configured. When a threshold is crossed, an event is generated using the alarm hysteresis mechanism. This section contains procedures that explain how to create or disable alarms.
